would this fit?
Old Nov 6, 2006 | 12:45 PM
superhatchbackbros's Avatar
Default would this fit?
would 97 honda civic front hubs and rotors and struts etc fit on a 88-91 civic/crx? i was told from 88-00 fits all? can someone confirm this?
Old Nov 6, 2006 | 01:09 PM
Rex-Si's Avatar
Default Re: would this fit? (superhatchbackbros)
to my knowlege they will not work. As a general rule of thumb you have to keep it in the same generation.
Old Nov 6, 2006 | 01:14 PM
then y does everyone say 88-00 civic's all?
Old Nov 6, 2006 | 01:34 PM
Cvic90's Avatar
Default Re: (superhatchbackbros)
If your talking about swapping the front steering knuckles from a 97 to an older civic. Yes it will work. but the camber will be way out. you will have alot of positve camber. if it was on a lowered car with an adjustable camber kit it should work out after an alignment. the shocks and springs differ from year and model. you jus have to try them and see if the ride height and spring rate works for you on your car.
Old Nov 6, 2006 | 10:22 PM
i got them. im going to just use my stock spindle etc and just see if the koni yellow with ground control sportline kit works on the ef. even tho they came off a 97 civic. i hope they fit.
t1g4
Apr 7, 2004 09:53 AM
dan89crxsi
Dec 1, 2002 08:16 PM
