h22 idle problem...need help
Old Nov 6, 2006 | 11:41 AM
dek1mfk's Avatar
Default h22 idle problem...need help
i swapped in a usdm h22 into my 92 prelude si...im running with a p13 ecu...when i turn the car on, its struggles a bit...once its turned on, it will idle at about 2000rpm...
once the car is warm, the idle drops to about 400rpm-600 and the car shakes and looks like its gonna shut off...
the gas pedal gets "stuck" and i have to floor it hard to make it get loose....when i try hitting the gas, from about 500-3000k rpm, the car chokes and makes these backfire noises....after 3000k rpm, the car runs normal
car also idles bad and i can smell raw gas coming out from the exhaust
any ideas what could be wrong with it?
Old Nov 6, 2006 | 03:25 PM
dek1mfk's Avatar
Default Re: h22 idle problem...need help (dek1mfk)
anyone?
wheelmaneg6
Nov 9, 2006 06:20 AM
jdmjonnyacc
Apr 26, 2006 10:13 PM
civicfanman
Apr 25, 2005 07:56 PM
