Msd pro honda dizzy (dont buy one)my problem
So i though i would share with everyone what happened to me at the track on sunday and why the pro billet dizzy suck *****.Until sunday i ahve not had a problem with this thing problems that people have had (ignitor driver going bad, random screws falling out,pin breakingor falling out) now i do haha. i called msd totoday and named off a list of problems that people have had and the tech guy said he hasnt heard of any of these problems. they gave me a RMA # to send it back told me i would get a new one... so who want a brand new msd dizzy haha... If you got one i would deff. check everything over in them often or send it back to them.T1 kit here i come
i made one pass really bad used the 1600cc map from my built motor a a base tune. i didnt have time to tune it threw it together took it to the track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">are you using the aem two step? Do you have it based off of your vss?</TD></TR></TABLE>
It is BUT my buddy said it doesnt seem to want to turn off which doesnt make sense since we havent changed a thing! Unless the speed sensor went bad or is unplugged?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one slow coupe »</TD></TR><TR><TD CLASS="quote">do you know why that even happened bret?
still not as bad as my problem
Did you have a problem with a MSD dizzy to? I was thinking about using one.. But IM still doing some reseach..
</TD></TR></TABLE>Did you have a problem with a MSD dizzy to? I was thinking about using one.. But IM still doing some reseach..
Fire up your laptop and take the car for a ride. I had the same problem where I thought my car was breaking up at high rpms. After dicking around with a new cap, rotor, plugs and a bunch of other things I found out my vss had stopped giving a signal or input to the aem. My speedo still worked but the aem was reading 0mph so two step would not shut off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">Fire up your laptop and take the car for a ride. I had the same problem where I thought my car was breaking up at high rpms. After dicking around with a new cap, rotor, plugs and a bunch of other things I found out my vss had stopped giving a signal or input to the aem. My speedo still worked but the aem was reading 0mph so two step would not shut off. </TD></TR></TABLE>
I will try that in about two hours or so, I will go to my buddie's house where I can pick up a brand new AEM 1040U box and also brand new MSD dizzy. I will check what you said first then try the MSD Dizzy if that doesnt solve it then try to download my Map itno the new EMS and try that. Wish me luck!
i told you or your guys to check that pin ive sheared two stock msd pins till i made my own and havent had a problem since.they make the pin to short and the load spinning it wears it out.
i made a new pin with a tighter fit and alittle longer to the edge of the ring to get a better bit.
sucs because i had a spare with me that you could of had to finish the day
definitely check that out, ive seen it more than once.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">precautions?
see my above post
see my above post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
see my above post
now, now dturd, dont go titliating vaporboy now ya hear
see my above post
</TD></TR></TABLE>now, now dturd, dont go titliating vaporboy now ya hear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">well atleast msd is replacing it.</TD></TR></TABLE>
yeah, with another piece of ****
to msd
to msd
ecotec distributor is a slight bit different, than the honda one, it use a hex key going into the cam, so it would not have this problem. Does you know good. Sorry you are having issues, we have used msd products on all our hondas ,gm's, fords, forever and never have issues. Most issues are install related, but this just looks like a faulty component. Msd is replacing it so I dont see the need to slam the product, nobody else has tried to come out with a viable alternative for the old honda distributors. Tony's trigger is great, but not an option for everyone.
Everyone is quick to jump on the band wagon and quick to jump off.....people act like this aftermarket stuff will never break...lol
good point jason but i think this thing is poorly made. first on my built motor the pin keep coming out and fin my head up. then ive had one of the ignitor driver boxes go bad on me which about 6 oither people i know have had the same problem. the damn thing is only a few months old.
How did the stock motor work out for you?
