98-01 oem foglights...
Im thinking of getting these for my gs-r. please post some pics of your front end with them. where did you get them from if they didnt come on the car, whats did you have to do to wire them up, what all comes with it
I got mine from A and H Motorsport, for like 210 they are great too, everything you need comes in the box like wires and relays its real easy to instal, you just have to cut the grille out a litte but that is cake...they look good too.
HTH
Tom O.
anyone have them on a white gsr? is the switch like the oem on the goes beside the parking break? can you replace the blubs for hyper whites? can they be wired up to be able to run just with parking lights or do your headlights have to be on?
[Modified by Pineapple Devil, 10:46 AM 5/7/2002]
can someone email me a copy of the wiring diagram for it please?
sam@samagon0.com
thanks in advance!
sam@samagon0.com
thanks in advance!
does anyone have them wired up to where you can run your parking lights and the fog lights w/o the headlights? like the trans ams can do
hm. http://www.handa-accessories.com used to have the installation instructions.. if that site is down still.. you might also want to try http://www.hondaautomotiveparts.com .. maybe if you special request the instructions they can send them to you via email.(adobe.pdf file)
they're the same foglights of the 99 civics and accords.. different brackets, wiring might differ as well. i have them on my teg.. the wire harness that came with it should hook up to a little brown plug(green arrow) found around the base of the windshield wiper fluid tank.. the ground was attatched to a bolt on the wiper fluid tank(pink arrow)
i'll keep searching the net for the file.. its really hard to find.. but i'm sure the honda/acura dealer would make a copy for you.
Full Race A6
Jul 16, 2004 11:29 AM
