brake lights...searched!
Alright here we go, i did research before i posted, i looked at every post with "no brake lights" in or related to it and didnt get a answer yet. I was searching and almost found a answer because someone asked if their horn worked and they never replied. So if that helps at all I dont have a horn either. I have no brake lights, i tested the brake switch on the pedal assembly and it works, gets power n everything. Replaced bulbs, still nothing, my tail lights work however but no brake lights. Fuse was good too, so im stuck. Also my reverse lights dont work. Anyone think they can help me out here? Greatly appreciated!
Little background information, this car has an SI wiring harness for the MPFI swap on a stock D15B2. We think the issue is unrelated however, but you never know.
Bump up for a good guy, we are stuck on this one!
Did you take the bulb out and check/replace? If they are dual purpose (two filaments, one for tail and one for brake) it is very possible that the brake died and not the tail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by didyouhearthat »</TD></TR><TR><TD CLASS="quote">Did you take the bulb out and check/replace? If they are dual purpose (two filaments, one for tail and one for brake) it is very possible that the brake died and not the tail.</TD></TR></TABLE>
happened to me
tho he said he changed the globes....
happened to me
MR Rodgers
Jan 5, 2009 02:32 PM
FullMetalJacket
12
Apr 29, 2003 10:07 AM
