ef d series into my eg
heres the deal, I have a 94 civic sedan with an h22 swap in it. Im in the process of rebuilding the engine, but when its done its not going back into the sedan, its going in a eg hatch. What I want to do is convert the sedan drivetrain back to stock. I found a good deal on an entire ef d15 civic swap(engine,axles,shifter linkage,harness, and so on). Will the axles and shifter linkage from an ef work on an eg? Is it difficult to convert the obd0 d series engine to obd1 computer system? will a obd1 d series tranny work with an obd0 d series engine? Is the swap even worth it?
not sure on the axles but to convert to obd1 you need an obd1 dizzy, alternator, fuel injectors, 4 wire o2, and throttle body and of course the ecu. you will also need a hydro tranny cause the ef one is cable. the linkage will work and you could sell the engine harness for a bill easy and use the stock engine harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethiks313 »</TD></TR><TR><TD CLASS="quote">Is the swap even worth it? </TD></TR></TABLE>
depends how much your picking it up for. actually you said d15... if its a d15b2 its not worth it at all the only way it might be worth it is if its a d16a6.
ek9kbomb'd
Jul 19, 2014 08:08 PM
dailydrivenHONDA
Jan 10, 2009 05:39 PM
