FS: 1988 Honda CRX Si - Greensboro, North Carolina
Old Nov 5, 2006 | 07:10 PM
chupacabrah's Avatar
Default FS: 1988 Honda CRX Si - Greensboro, North Carolina
I have a 1988 CRX Si in pretty good condition. glossy black, except hood is primered black.
Black Interior is in very good condition. Seats are from an integra, and were recently re-covered.
Engine rebuild has < 5k on it (3000 and some change, I think).
D16a6 with pm7 (dohc zc) internals,
metal headgasket,
ported head,
arp headstuds,
dohc zc header and full exhaust (**no cat**).
11.6 :1 compression ratio.
Build and porting on the head was done by John (finalimpact on CarolinaHondas).
5spd (a6 tranny)
Short ram intake
Has seen synthetic or synthetic blend oil since it was rebuilt. (Castrol Syntec blend, 5w30)
I'm currently using a PG7 ECU. and I will include an OBD0 PR4 ecu (chippable) with the sale of the car.
Unknown miles on body, odo says 237k. Not stock gauge cluster.
working Sunroof
00 si wheels in good condition with almost new kumho 711's.
Sound system, 4 speakers powered by a 360 watt(i think) amp, and a 10" alpine type r sub powered off of a sony 400 watt amp. I'm not positive about the watts of the amps.
Windows are tinted.
Has Current NC inspection
Ground Control Coilovers, with stock shocks
Xenon polyeurethane front bumper
AC WORKS!!
Full tank of gas :bandit: (varies as I continue drivng the car)
Also Included with car:
1 std civic driver side axle
1 dohc zc flywheel
1 d series starter - broken top bracket
1 LS throttle cable
1 d16a6 oil filter (Honda)
ONLY problems are as follows:
-the IACV is disconnected, just needs to be hooked up. So currently the Idle pulses.
-It would definitely benefit from a chip/tune/something. right now it does ok powerwise, and gets around 30ish mpg. but it could be better.
-the cd player plays the cd that is in there, but for some reason wont eject it??
-there's no antenna on the car = no radio
-does leak a little oil from the valve cover gasket, on the right side. i think it just needs to be resealed.
-There is only one small spot of rust on the car, it's on the passenger rear wheelwell.
-1 CV axle clicks (of course only in sharp turns)
Other than that, I drive the car almost every day. It gets around 30 mpg city.
For a SOHC non-Vtec it makes VERY good power, mostly over 4000 RPMS. Below there, it's not too weak, it's just not quick. it is a 1.6 ltr D series....
But this car is very fun to drive, and like I said makes decent power (even untuned!)
The only, ONLY, problem with how this car runs is the idle. At Idle it drops down, and pulses back up to 3k, and drops down, so on and so forth. This is at idle. When driving, the car is fine and normal.
Price is $2000
NO trades! I need the money to fix my other car!
Best means of contact are reply to this thread or email: jonr@triad.rr.com
Thanks for looking
11/05/06 !!
(thumbnails, click to enlarge)
Thumbnails (click to enlarge):
Modified by chupacabrah at 11:40 PM 11/5/2006
Old Nov 6, 2006 | 11:47 PM
leoverte's Avatar
Default Re: FS: 1988 Honda CRX Si - Greensboro, North Carolina (chupacabrah)
i am interested in your car...can you get a hold of me...
Old Nov 6, 2006 | 11:48 PM
leoverte's Avatar
can you call me at 856-498-0254
Old Nov 8, 2006 | 03:36 AM
Default Re: FS: 1988 Honda CRX Si - Greensboro, North Carolina (leoverte)
hi, i've just seen your reply.
I will try to call you this afternoon. You can email in the meantime, if you wish.
Thanks!
Old Nov 14, 2006 | 05:35 PM
1 Fly SI's Avatar
do you still have it?
Old Nov 14, 2006 | 07:00 PM
Default Re: FS: 1988 Honda CRX Si - Greensboro, North Carolina (1 Fly SI)
I do, but sale is pending for a day or so....
But it's still available as i dont have cash in hand...
Old Nov 17, 2006 | 02:16 PM
SOLD!
close thread pls!
NACvicSi
Southeast (Sales)
Dec 7, 2009 01:40 PM
lil vin
Mar 22, 2009 08:14 PM
GroundZer0
Oct 23, 2003 11:09 AM
