93 d15b8, 2 or 4 valve reliefs per piston?
Old Nov 5, 2006 | 04:38 PM
Sketch_hs's Avatar
Default 93 d15b8, 2 or 4 valve reliefs per piston?
need to change the HG and was thinking about putting a spare d16 vtec head on it for fun
Old Nov 9, 2006 | 09:28 PM
Sketch_hs's Avatar
anyone know
Old Nov 10, 2006 | 12:03 AM
skunk_duece's Avatar
4 reliefs... they run a 8.0 PM6 code piston. Same as the old HF motor. Not sure how it'll run with the lower compression on 4 valves.
Old Nov 10, 2006 | 05:40 PM
Sketch_hs's Avatar
Default Re: (skunk_duece)
sweet, cause i'd much rather put the vtec head on than the poopy 8 valve
Old Nov 11, 2006 | 05:07 PM
lek9l's Avatar
Default Re: (Sketch_hs)
D15b8 has only 2 valves per cylinder. Good on gas, bad for performance. I like the rocker arms on it.
Old Nov 12, 2006 | 04:26 PM
Sketch_hs's Avatar
Default Re: (lek9l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lek9l &raquo;</TD></TR><TR><TD CLASS="quote">D15b8 has only 2 valves per cylinder. Good on gas, bad for performance. I like the rocker arms on it.</TD></TR></TABLE>
we aren't talking about valves, we are talking about the valve reliefs on the pistons.
Some d15b8 motor have 2 per cylinder, some have 4. Obviously you can't to a minime on a 2 valve relief/cylinder motor
mayfly
Jun 17, 2012 09:17 AM
mayfly
Jun 16, 2012 06:02 PM
zccrx
Dec 9, 2008 01:44 PM
B18Sleeper
Dec 31, 2007 03:29 AM
