Need help with my zc
Old Nov 5, 2006 | 03:06 PM
ZCPoweredHatch's Avatar
Default Need help with my zc
Alright i got my zc up and running but there is some white smoke coming out of the exhaust..The higher i rev the more the smoke.. I am getting two codes knock and o2.. But i just put in a new o2 yesterday and reset my computer.. It also seems kinda slow.. Yea i know its a d-series.. I know that these motors arent this slow because my D16 was faster then this.. Also When my car warms up now it just shuts off.. It will get right around the half way mark on the temp gauge and then my car will just shut off..Wont start till it cools off a lil.. The car will pop and back fire alot.. Anyone know what the problem is??
Old Nov 5, 2006 | 03:08 PM
B16 IIgen's Avatar
Default Re: Need help with my zc (ZCPoweredHatch)
its prolly your TPS throttle position sensor... when i did my friends swap it was doing the exact same thing so hope that helps
Old Nov 5, 2006 | 03:12 PM
But im not showing that code. If there was a problem with at wouldnt it be extreamly jumpy when i try and give it gas?
Old Nov 5, 2006 | 03:15 PM
Ita a dohc zc and it was obd0. Im running a p75 computer on it.. Will it matter if my computer isnt bolted up..Its just layin on the floor in my car.. I was told that it should be bolted up cause then its not getting the same ground as the rest of the car or something like that
Old Nov 5, 2006 | 03:35 PM
Really needing help here...Bump
Old Nov 7, 2006 | 11:52 AM
Can some one plz help me out..
ohgodbadname
16
Aug 10, 2012 08:19 AM
DB'd
13
Nov 11, 2004 03:15 PM
hondaless
Aug 25, 2002 01:00 AM
