Need Help with Brake Lights with 99 Civic EX
My brake lights are no longer working. We have checked the obvious things like the bulbs and the fuse under the hood. We have even checked the continuity of the brake light switch and it appears to be working. For whatever reason, the power is not reaching the bulb in the back of the car. We have looked at a couple of different wiring diagrams. One of which shows some sort of relay (J/C C442) that is supposed to be mounted under the right kick panel which we cannot find (the relay). Another doesn't show a relay at all.... This is my daily driver and anything that you can do to help us figure this out would be greatly appreciated.
Thanks,
Rachel
Thanks,
Rachel
Well this post should be in this section https://honda-tech.com/zeroforum/1 , try re-posting there and you should be able to get more help.
It's just that this is the ef civic and crx board and your question belongs in the threads designed for your cars year and model.
MR Rodgers
Jan 5, 2009 02:32 PM
Rachel's 99 Civic
Nov 5, 2006 04:03 PM
