5gen suspension has sqeesh sound
Old Nov 5, 2006 | 10:32 AM
stocktonhidlude's Avatar
Default 5gen suspension has sqeesh sound
when i shift,(3500rpm) i hear some sqeesh should from the suspension. i check but can't find anything. edit(the sound is from the from passenger side, if i pop the hood and rev the engine....i didn't hear the sound....it only hear when driving).
Modified by stocktonhidlude at 12:05 AM 11/6/2006
Old Nov 5, 2006 | 10:35 AM
K-Spec's Avatar
Default Re: 5gen suspension has sqeesh sound (stocktonhidlude)
where is it coming from...front or rear...driver or passenger side? does it only happen when you shift or when you go over bumps too..?
Old Nov 5, 2006 | 05:16 PM
BB6racer's Avatar
shifting should not affect your suspension at all, except for the fact that your car squats and dives slightly when shifting. the noise should happen when your suspension experiences quick load changes. you could either be hearing shock knock or squeeky bushings. have you recently installed new suspension components or does you car have aftermarket suspension already. sometimes people don't lubricate the bushings when they re-install suspension and it comes back to haunt them later.
Old Nov 5, 2006 | 06:42 PM
94vtirozguy's Avatar
might be broken engine mount
Zanzapod
Nov 19, 2011 05:41 PM
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
lude-tec
Suspension & Brakes
Mar 31, 2006 12:49 PM
