00 civic fuel help.
Old Nov 5, 2006 | 08:46 AM
mafia's Avatar
Default 00 civic fuel help.
Will a fuel pump fit from a 00 gsr fit a 00 civic? I have a 00 civic hatch and a b16 fuel pump (with b18c5 motor) And my Rpm's dont go past 8100 rpm's so im thinking its something with fuel.
Old Nov 5, 2006 | 08:47 AM
Eran's Avatar
HT White Ops
What ecu are you using?
Old Nov 5, 2006 | 09:28 AM
mafia's Avatar
Default Re: (Eran)
obd1 p73 skunk 2 chipped. (turns motor off at 9500 rpms)... It feels like too little of fuel is going to the motor.. I tryed my obd2 b16 ecu and same problem allthow if the rpm's get pass 8100 the it shuts motor off (you can feel it) If you want i can take a video with b16 ecu and p73 ecu. (if that will help you see what the problem is)
Old Nov 5, 2006 | 09:35 AM
Ls_V_TurboSi's Avatar
Default Re: (mafia)
I'm not sure of the fuel probelm but yes the fuel pump will fit... we did this on my cousins cars, if I remember correctly, we too the actual fuel pump and all of its mechanims and stuck it on the si fuel pump bracket.. you should be able to figure it out when you look at it
Old Nov 6, 2006 | 07:13 AM
mafia's Avatar
Default Re: (Ls_V_TurboSi)
will obd2a fit a obd2b fuel pump? (the wriring on it)
00civicnewb
Nov 9, 2014 01:45 PM
Ek4 life
Jul 27, 2008 03:22 PM
Ek4 life
Jul 27, 2008 12:02 AM
