need help making list of parts for swap... help if can... mahalos
so i want to convert my prelude from auto to manual. i know i need alot of parts but heres my list of what i know i need. please post up any parts that should be on my list.
1. clutch and brake pedal assembly
2. clutch slave
3. clutch line
4. shift linkage
5. shifter, ****, and boot
6. new mounts
so add any other parts i need for this conversion.
mahalos,
rob
2. clutch slave
3. clutch line
4. shift linkage
6. new mounts
mahalos,
rob
I suggest you get an M2B4, i have one and can vouch for their handling abilities.
2. clutch slave
3. clutch line
4. shift linkage
6. new mounts
also add:
Clutch damper and lines
ECU
Master cylinder (new is best)
intermediate and half shafts
1-2 litres of gearbox oil (OEM Honda MTF will do fine)
You may also wish to add:
Lightweight flywheel
New Clutch
You may find that your cars chassis transmission mount is 20mm too short, you will have to loosen all mounts and lever the transmission mount in place first.
2. clutch slave
3. clutch line
4. shift linkage
6. new mounts
also add:
ECU
New Clutch
