EF parts for 4dr! ZC parts too!!
Old Nov 4, 2006 | 04:50 PM
LigerZeroWPC's Avatar
Default EF parts for 4dr! ZC parts too!!
so I have to get rid of some parts and yeah I need
some cash too. but here they are. all work and
shouldn't be damaged and yeah if your in the LA area
thats even better cause your near and you can pick up
or what not.
1. USDM front end includes:
Hood,
fenders,
bumper,
bumper filler,
rad support,
bumper signals (clear or amber),
corner lights either jdm style amber or clear(i have
both),
head lights with bulbs.
2. rear drums (brakes still good (with cables)
3. ITR rear lower arms
4. stock intake box
5. center thingy where your shifter and handbrake
thing are at(that piece haha) brown in color
6. 88 civic glove box (vanilla in color)
7. ZC power steering pump
8. ZC flywheel
9. ZC clutch disc and preasure plate (looks good)
10. 88 civic stage 1 racing clutch (Gripforce) <--I
belive its an east coast brand not sure but grippy
11. alternator (works)
12. rear calipers for disc conversion (not sure they
work but you can rebuild of course)
13. stock camber (front)
14. ZC intake manifold
15. D15 exhaust manifold (ends ported)
16. ZC head (rebuilt and shaved all you need is stem
seals)
17. ZC valve cover black in color
18 ZC block (still very good 180 psi on all cylinders
no leaks) bolts right into your 88-91 civic
19.30/30 porportion valve haha
20. stock shifter
21. ZC PM7 ecu manual
22. Pm5? stock D15 dpfi ecu manual
23. mpfi little injector box thingy (needed for multi
port conversion
24. gas door cable with latch
25. 4 intake and 4 exhaust ZC stem seals (brand new in
Honda baggies)
26. 2 intake and 2 exhaust ZC valves brand new in box
27. dpfi gas cable
28. 2 93 prelude rims no tires (scratches but perfect
of for spare tire use
29. dpfi intake manifold with injectors and etc for
ultimate race perform..... nvm haha
30. spare dpfi throttle body
31. jdm nissin rear brake pads used but i dunno why i
still have them
32. jdm rear sway bar for the ITR or CTR
33. haha volkswagen jetta roof rack for bikes (wtf)
34. rear discs (2 discs thats it) need to be turned
but thats all shoul still be good for someone
35. 88 civic DX steering column
36. 88 civic gauge cluster DX
37. 88 civic tail lights both
38 88 civic tail lights (extra ones 2 right)
and yeah thats all I can think of right now
wow thats a lot of shiat and i think when i get home i
will probably add more
Slver87si
Nov 14, 2016 04:55 PM
quirarte626
May 4, 2010 02:17 PM
90CRXracer
Dec 23, 2003 02:27 PM
