Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles??
Old Nov 4, 2006 | 03:53 PM
VtecSyndrome's Avatar
Default Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles??
As the title says, I have a set of crossdrilled rotors and pads from my wrecked '91 Si and want to put them on my '89 DX CRX. will they bolt up or do I need to swap the whole spindle over? I searched but could not find this exact question anywhere.
Old Nov 4, 2006 | 06:14 PM
liquidoblivion's Avatar
Default Re: Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles?? (VtecSyndrome)
DX/LX/Si all have the same brakes.
Old Nov 5, 2006 | 09:11 AM
Default Re: Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles?? (liquidoblivion)
No they don't........ I am guessing the spindles are the same but the calipers are 100% different, believe ME, I have both cars in front of me so there is no debate there. please does ANYBODY else actually know if this works w/o me having to try it first?
Old Nov 5, 2006 | 03:21 PM
Bump.....wow, I'm verysuprised nobody chimed in yet?? I may just have to figure this one out myself?
Old Nov 6, 2006 | 10:06 AM
T3T4H22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">No they don't........ I am guessing the spindles are the same but the calipers are 100% different, believe ME, I have both cars in front of me so there is no debate there. please does ANYBODY else actually know if this works w/o me having to try it first?</TD></TR></TABLE>
They are the same. Make sure you have them on the right side. Or maybe you got the front and back calipers from the 91 SI mixed up. If you think i'm talking out of my *** i'm not I had to swap calipers from my CRX SI to my GF's Turbo EF and it was the same and before that I order new rotor and all of the part numbers were the same. If it don't fit you doing something wrong.
Old Nov 6, 2006 | 10:19 AM
Tyson's Avatar
it will fit fine.
88-89 all front calipers are the same. (except HF)
until the 90-91 crx si calipers that are different.
but the spindle/knuckle and rotors remained the same. so itll bolt up.
Old Nov 6, 2006 | 02:48 PM
Default Re: Will 91' CRX Si calipers and rotors bolt up to '89 DX spindles?? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">it will fit fine.
but the spindle/knuckle and rotors remained the same. so itll bolt up. </TD></TR></TABLE>
Thank you, that is what I wanted to know! The pads are different on both cars so thats why it was a no brainer on the fact thay they are different. anyway good to know the spindles are the same, that is what I really needed to know.
rice_classic
Jan 8, 2005 10:14 AM
gringo7718
Sep 24, 2004 09:12 AM
MAD SCIENTIST
Apr 19, 2004 06:05 PM
RotiEatter
10
Jul 24, 2003 12:52 PM
xXx Justin xXx
Aug 28, 2002 11:59 AM
