GSR Endlinks no no on ek
I got a gsr rear swaybar for 50, come complete with everything. Found out the endlinks wont work on my ek......so what are my options. What do a set of used or new 99-00si endlinks go for and what can i get for the gsr endlinks? I would like the cheapest solutuion, cause im a poor high school student.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">why r the teg endlinks cheaper? Also, can i modify the lca's to accept the gsr endlinks?</TD></TR></TABLE>
They're cheaper because they only work on teggys and 92-95, and no you can't really modify them to work. They don't mount/work the same way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">would the blox racing ones on HT be a good choice?</TD></TR></TABLE>
Far better than trying to modify a GSR endlink.
Nother question. Would it be easier or cheaper to swap some ITR Rear LCA's on my ek? How much work is envolved? Password sells them for 50 a pair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">Nother question. Would it be easier or cheaper to swap some ITR Rear LCA's on my ek? How much work is envolved? Password sells them for 50 a pair. </TD></TR></TABLE>
Wouldn't work. You need to stop cheaping out on this. If money is so much of an issue that you can't afford $100 for endlinks to put on a sway bar, then stop modifying your car. There's a difference between being thrifty and being a cheap-***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy »</TD></TR><TR><TD CLASS="quote">anyone know if those are 45 each or for two?</TD></TR></TABLE>
$45 for the pair.
$45 for the pair.
Ya well i got no chice, but it will be a good upgrade. Also this guy is givving me 100 for my stock springs and upper A arms, so ill just be using that money. I cant wait to put it on tho.
SuperCivic
Jul 22, 2004 03:04 PM
