Need some help with aftermarket tach.
Old Nov 4, 2006 | 09:48 AM
90crxdriver's Avatar
Default Need some help with aftermarket tach.
Ok I got a tach and tryed to install it the only problem is which wire to connect the green tach feed wire to. The honda tech manual says the blue wire from the coil is the stock tach feed. So I spliced into it and I get no reading on tach. Also the selector switch on tach is set to 4 cyl.
Anyone have any ideas why it wont work. thanks
Old Nov 4, 2006 | 09:49 AM
crxnj's Avatar
Default Re: Need some help with aftermarket tach. (cordiaturboowner)
stupid question, but do you have the power wire hooked up?
the blue wire on the dizzy or at the ecu is the correct wire so it should be working.
Old Nov 4, 2006 | 09:57 AM
Discontained's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cordiaturboowner &raquo;</TD></TR><TR><TD CLASS="quote">Ok I got a tach and tryed to install it the only problem is which wire to connect the green tach feed wire to. The honda tech manual says the blue wire from the coil is the stock tach feed. So I spliced into it and I get no reading on tach. Also the selector switch on tach is set to 4 cyl.
Anyone have any ideas why it wont work. thanks</TD></TR></TABLE>
Get a Inline Slpicer. They looks like this. they
are usually blue. Connect that to the Distributor on the 2 wire plug. I belive its the blue wire. Make sure you have a good ground. as well for pwr
Old Nov 4, 2006 | 10:05 AM
janz3n's Avatar
Default Re: Need some help with aftermarket tach. (Discontained)
if you dont want to run a wire all the way to the engine you can use the blue wire behind the cluster ... all hondas have the tach wire theres just no connection if you car doesnt have a tach. this is what i did and works great.
Old Nov 4, 2006 | 10:10 AM
Default Re: Need some help with aftermarket tach. (janz3n)
ground is good
switched power in good
battery power is good
I'll try to hook it up behind the cluster.
I might have bought a bad tach to Its off ebay so maybe thats the problem. It is new in box so I don't know. I'll try to hook it up on my brothers car to see it it will work also. but thanks for the quick replys
Old Nov 4, 2006 | 10:27 AM
post a pic of the tach and the wires
Old Nov 4, 2006 | 10:44 AM
Default Re: (Discontained)
yellow is acc switched power
red is battery
black is ground
green is tach feed
Old Nov 4, 2006 | 10:49 AM
ok, who makes it?
Old Nov 4, 2006 | 10:52 AM
this is off the ebay page
Old Nov 4, 2006 | 10:56 AM
Hmmm, well here is what i would do, Hook the wires back up,
Pwr to fuse box
Yellow to lights or the fuse for a quicktest
Black ground it out
Green goes into the dizzy plug where the Blue wire is.
start the car up. see if it still fucked up. then post back :D
Old Nov 4, 2006 | 12:14 PM
Default its alive
I rewired everything and got it to work. Endedup being bad wire that I pulled into the engine compartment.
sweet its installed (it doen't reflect that bad the camera make it worse.)
Tyson
40
Jun 4, 2009 04:24 PM
littleblue
Nov 4, 2008 08:29 AM
esean93
Aug 23, 2008 10:33 AM
b_serious
12
May 11, 2006 04:26 PM
1sikhatch
11
Mar 14, 2006 09:19 PM
