D16a6/y8 (minime) Into 87 CRX
Old Nov 4, 2006 | 04:26 AM
Global688's Avatar
Default D16a6/y8 (minime) Into 87 CRX
Searched around couldnt find an answer. I got a 91 civic sedan that i have the minme in. Once my ship gets off deployment im going to put that engine into my 87 crx and turn it into my track car.
Was there anything special that i needed to do to drop it in?
i.e axles, linkege, etc....
A k24 is going into the sedan case anyone was wondering.
Old Nov 4, 2006 | 05:37 AM
joethejoeman's Avatar
Default Re: D16a6/y8 (minime) Into 87 CRX (Global688)
wat type of moter did it come w\,
i no some 88 crx's come w\ d16a6 , so if its the same block u shouldnt need to get mounts, but im not sure wat block u got,
Old Nov 4, 2006 | 07:42 AM
86crxb16's Avatar
Yes what kind of motor is in it?
When I put my 93 B16A into my 87 Crx I needed new Hasport Engine/Trany mounts. The tranny need minor welding but fit smooth.
To switch over the wiring harnesses I had to get a connector or adapter from 93' JDM to 87' USA was time consuming and a little extra money than i wanted but well worth it because your CRX will still be stock inside and plug/play.
Youll need/Want 91' and up integra front axles and new ones made for acura integra.
New shift Linkage and you should be good to go.
Post more if any questions no email so.... 86CRX
Old Nov 4, 2006 | 08:58 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
http://www.redpepperracing.com
Read the FAQ and search in the Technical--&gt;Swaps forum. No one makes mounts to swap an 88+ d-series into an 84-87 Civic/CRX so they'll have to be custom made. A few have done it, but it is very few because it's rather a PITA and most people who are going to go to that much trouble will swap in a b-series. You will also find a lot of threads here on H/T that discuss it if you search in the <u>CRX / EF Civic</u> archives for "d16a1".
Old Nov 4, 2006 | 11:28 AM
Global688's Avatar
Default Re: D16a6/y8 (joethejoeman)
Its a D15 somthing or another. (DX model) Not sure which one but i belive it makes 89hp and its carberated.
Old Nov 4, 2006 | 12:26 PM
86crxb16's Avatar
Default Re: D16a6/y8 (Global688)
Whats the motor you are looking to swap into the 87?? To be honest i dont know if u want a D15A to be your track motor.
Get back to me. 86CRX
Old Nov 4, 2006 | 01:49 PM
Global688's Avatar
Default Re: D16a6/y8 (86crxb16)
my minime swap
Old Nov 4, 2006 | 09:25 PM
put ur k24 in ur rex,
it would be fast as hellllllllllllllll
vATTACK
Mar 6, 2006 10:26 AM
jagged4698
Aug 1, 2004 06:13 PM
NewIntegraKid
34
Mar 3, 2003 01:41 PM
russian_racer
Sep 15, 2002 02:07 PM
Red Civic T
Dec 13, 2001 07:08 PM
