HELP can you swap prelude transmission into accord
Old Nov 3, 2006 | 09:44 PM
Honda_ThuGZ's Avatar
Default HELP can you swap prelude transmission into accord
can u swap a prelude manual tranny (in general, if so what year)
without havin to swap the stock Vtech
into a 97 accord F22 series vtech (manual tranny)
Modified by Honda_Rydahz at 5:47 PM 11/4/2006
Old Nov 4, 2006 | 10:06 AM
KageOokami's Avatar
Default Re: HELP can you swap prelude transmission into accord (Honda_Rydahz)
Swap the what???
It's VTEC...not VTECH. Jebus...
Old Nov 4, 2006 | 10:30 AM
standbackimapro's Avatar
The H22 Transmission Will fit on the F22
Old Nov 4, 2006 | 10:33 AM
KageOokami's Avatar
Default Re: (standbackimapro)
You also have to change the auto flywheel to the manual one. Just make sure they do it right otherwise your engine will sit crooked. A couple guys swapped transmissions and after that their engine was sagging to one side.
Old Nov 4, 2006 | 11:08 AM
raceACCORDingly's Avatar
he didnt even mention doing a manual conversion.
he didnt mention what prelude (f22, h23, h22) tranny.
but anyways as long as its not an ATTS tranny then it will bolt right up.
Old Nov 4, 2006 | 12:33 PM
TOAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">The H22 Transmission Will fit on the F22</TD></TR></TABLE>Do you want to find out what the hell you're talking about first?
Old Nov 8, 2006 | 03:55 PM
beef7567's Avatar
Default Re: (TOAB)
I have a 1996 honda accord vp automatic. I changed the tranny once because the tranny went out and now its starting to slip again. I wonder if I can swap a prelude tranny and would that work better than getting a new/used/rebuilt tranny again.
Old Nov 8, 2006 | 06:27 PM
rollercosta123's Avatar
Default Re: (raceACCORDingly)
what is ATTS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">
but anyways as long as its not an ATTS tranny then it will bolt right up.</TD></TR></TABLE>
Old Nov 8, 2006 | 08:27 PM
iam7head's Avatar
Default Re: (rollercosta123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 &raquo;</TD></TR><TR><TD CLASS="quote">what is ATTS?
American Texan Teamster of the South, they are know for blewing up anything over 250-300whp. oh, also found in SH prelude 5th gen
Old Nov 9, 2006 | 08:50 AM
Default Re: (iam7head)
is this a joke?
Old Nov 9, 2006 | 09:26 AM
sixfiveoh's Avatar
Sweet Title
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 &raquo;</TD></TR><TR><TD CLASS="quote">is this a joke?</TD></TR></TABLE>
lolll
ATTS is Active Torque Transfer System
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When a front-drive car hustles around a corner, its front tires have to perform an extra function--power transfer--that the front tires on a rear-driver don't. That's why even very good-handling front-drive cars like the Prelude are more prone to understeer than their rear-drive counterparts.
Understeer describes a car's resistance to turn-in. The faster the entryspeed to a given corner, the more the car wants to go straight ahead. ATTS addresses this trait through a clever set of mechanical functions that automatically transfers available engine torque--as much as 80%--to the outside front wheel, and also increases its rotational speed by as much as 15%, putting the extra power into the outside front wheel, which typically bears the heaviest load in hard cornering, compensates for the extra load and restores balance.</TD></TR></TABLE>
Old Nov 9, 2006 | 10:06 AM
Default Re: (sixfiveoh)
is this only with atomatic trannys? why does everyone say to avoid these when doing a swap?
Old Nov 9, 2006 | 10:30 AM
sixfiveoh's Avatar
Sweet Title
no, it only came in the Type SH, and the Type SH only came in 5spd. They say avoid it if you plan on building your motor past 250hp
Logan Ricketts
Apr 4, 2019 03:52 PM
Accord01324
Apr 19, 2007 05:09 PM
luderollin
Jul 15, 2005 01:08 AM
chrisir19
Dec 22, 2003 09:27 PM
