To all the guys who have dizzy's that dont line up with the bolt holes
what are you using that wont bolt up right? when i had my hatch i was using a d16z6 with a d16a6 dizzy. These don't match so i drilled and cut out the top and front bolt tabs, on the dizzy not the motor, in a hook shape so they would still hook over the bolt but i could rotate the dizzy enough to tune it correctly. You will also need to use large diameter washers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdminthemakin »</TD></TR><TR><TD CLASS="quote">wow</TD></TR></TABLE>
WOW is right as i look at that more i am amazed at my own design. HOLY @#$$ that is a jimmy rigged setup.
It also depends on the dizzy as to how well each method works too!
lol...jimmy rigged setup?...never hurd that one..but hey it works 4 me fine..TIMES ARE HARD...not really but it was fast an easy swap to do by my self ( first ever swap took me a day an a half.. with no chek light wen i was done) sorry 4 spelling im dead sleepe....
sweeet thanks! I tried the zip tie route but leaked oil and **** sputterd past 3k lol, then i went to JB weld, still didnt hold, and now i have it camping in the garage. Ill find some brackets and ****, Thanks guys!
germanturtle
Nov 13, 2011 07:42 PM
