Swaping gsr cluster to jdm cluster
hi ya'll kind of new to this but i am planning on swapping my 95 gsr cluster to jdm cluster 98-01.. is there any thing i should know before attempting this.. Is it all plug and play? Thank you so much
It will physically fit, but you will need to do a few things to make it work properly. You need to swap over the individual (gas, temp, speedo, tach) from the JDM cluster housing to the 95 cluster housing. Then take the right most icon triangles from the 95 cluster bezel and swap it onto the JDM cluster bezel (if Type-R), and then place the JDM bezel onto the 95 cluster housing.
Use this as a guide https://honda-tech.com/zerothread?id=837111
