1989 Honda accord exi shifts hard
Old Nov 3, 2006 | 04:22 PM
ghomer's Avatar
Default 1989 Honda accord exi shifts hard
It was fine when I test drove it but now after driving it a few hours, it shifts hard and I have to let off the gas to get it to shift in to OD... now that I have drove it 4 times..it is doing it all the time. Fluid is fine etc... Somebody mentioned transmission vacuum modulator ?.. If the car has one, where is it thanx.
Old Nov 3, 2006 | 04:50 PM
hondadude's Avatar
Default Re: 1989 Honda accord LXi shifts hard (ghomer)
Check the shift pressure cable adjustment, it is attached to a lever on the front of the trans. Just as the idle speed starts to increase the pressure lever should barely start to rise.
Old Nov 3, 2006 | 04:55 PM
ghomer's Avatar
Default Re: 1989 Honda accord LXi shifts hard (hondadude)
so losen it off ?..just a bit ?.. I am new to Honda's.. I know GM 700r4 you one click either way to adjust but the lever adjustment on these will be harder.. Thanx for the reply to this also.
Old Nov 3, 2006 | 07:19 PM
YeuEmMaiMai's Avatar
chane fluid and use honda atf plus 1 can lubeguard for IMPORTS
bigd85yota
Feb 10, 2020 11:07 AM
steven.shutz
Sep 12, 2012 07:43 PM
Shinghi
Mar 3, 2012 08:37 PM
pdxaccord
Oct 8, 2007 06:59 PM
1994 Accord EX
Jun 6, 2005 05:45 PM
