Honda ECU p13 p28
use the seach option to get a few answers on choices. but from what i have seen, chipping is a waste. also do you have a sluch box or manual tranny. if you have a p28 you might as well run upgraded software to run you ecu and leave the chipping alone.
you have an h22...p13 is the factory ecu... there is your logical choice. the p28 will not have the secondary controls that you need for vtec. so if you want to lose those then go ahead and get it...but if you want to keep them then you should probably stick to the p13
if you want to run hondata in the future then the p72 is your best bet
EG-SIXV-TEC
Engine Management and Tuning
Jan 3, 2014 07:57 PM
MontanaSFS
May 18, 2008 09:50 PM
