GSR Header and Type R Header Question
Does anyone know if the 00-01 GSR header length is the same as the 00-01 USDM Type r headers? or is it the 00-01 type r headers the same length as the other ones regardless of the years?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NsX_CrX »</TD></TR><TR><TD CLASS="quote">Does anyone know if the 00-01 GSR header length is the same as the 00-01 USDM Type r headers? or is it the 00-01 type r headers the same length as the other ones regardless of the years? </TD></TR></TABLE>
All of the '00-'01 Integra manifolds/headers are completely interchangeable. The '94-'99 GS-R uses a shorter manifold than the rest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
All of the '00-'01 Integra manifolds/headers are completely interchangeable. The '94-'99 GS-R uses a shorter manifold than the rest. </TD></TR></TABLE>
The only header that isn't interchangable is 94-99 GSR like Padawan said. Everything else ranging from RS all the way to Type-R, and 00-01 GSR too, are interchangable.
So, that means that I can use a 94-99 header/manifold as long as it's not a GSR one? thanks for the answers
EVERYTHING besides the 94-99 GSR header is interchangable.
So the answer to your question is yes. Anything between 94-01, besides the 94-99 GSR, is swappable.
*edit - so you're putting an ITR header on your 94-99 GSR? Just slice out a piece of the exhaust like I said.
Modified by Hatch_R at 11:39 PM 11/4/2006
So the answer to your question is yes. Anything between 94-01, besides the 94-99 GSR, is swappable.*edit - so you're putting an ITR header on your 94-99 GSR? Just slice out a piece of the exhaust like I said.
does anybody know of any height differences in any of the b-series headers? which would be the tallest that would fit on GSR? Im having a problem where i keep getting headers that dont clear the oil pan.
ALLMOTOR18
Feb 3, 2004 09:41 AM
RedStarGsr
May 22, 2003 06:37 AM
