91 s1 b16 ecu code 21
Old Nov 3, 2006 | 12:21 PM
HU MAN CHU's Avatar
Default 91 si b16 ecu code 21
ok i went through the steps to check all components for this code all wiring is good and i've swapped for a known good ecu and still problem persists, it only comes on after 15 minutes at highway speeds 75-80, under that no problems, i need to figure out what else i could do to remedy this problem.....
Modified by HU MAN CHU at 7:38 AM 11/4/2006
Old Nov 4, 2006 | 04:51 AM
HU MAN CHU's Avatar
Default Re: 91 s1 b16 ecu code 21 (HU MAN CHU)
anyone
Old Nov 4, 2006 | 04:56 AM
civicjdmb16a's Avatar
21*
VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
You can start from there
Old Nov 4, 2006 | 05:25 AM
Autoworks's Avatar
Default Re: 91 s1 b16 ecu code 21 (civicjdmb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjdmb16a &raquo;</TD></TR><TR><TD CLASS="quote">21*
VTEC Solenoid Valve
try swapping the solenoid and check the oil level
Old Nov 4, 2006 | 06:36 AM
HU MAN CHU's Avatar
Default Re: 91 s1 b16 ecu code 21 (Autoworks)
ok, ive looked for that part and it goes by another name because vtec solenoid valve isnt sold at any auto parts store, i know what part it is and ive checked all the circuits, all came back good, ive followed the steps in the factory repair manual for troubleshooting, and if all steps prove good it doesnt say to swap a good part...is there any other part that can give me this symptom, oil level is good, maybe low oil pressure
Old Nov 4, 2006 | 07:51 AM
if your oil pressure sensor on the vtec soleniod was bad you would get another code.
I dont think you can just buy one at an autoparts store. If you want one new you might have to go to honda. It goes by "spool valve"
Do you have vtec?
Old Nov 4, 2006 | 03:30 PM
HU MAN CHU's Avatar
yes i have vtec
Old Nov 4, 2006 | 07:54 PM
DoHcZC91si's Avatar
well if you have vtec then you shouldnt be throwin a code for it. try reseting your ecu
LSracing94
Mar 30, 2022 04:11 PM
denraweb
Aug 22, 2007 03:14 PM
r7
11
May 29, 2005 12:55 PM
gots_a_sol
Aug 4, 2004 05:32 PM
