Just put in my USDM ITR cluster..weird problems
Old Nov 3, 2006 | 11:40 AM
a1320addict's Avatar
Default Just put in my USDM ITR cluster..weird problems
Hey, I purchased a USDM ITR cluster, and I've got some weird issues, wanted to know if any of you guys could be of some help.
It's going into my 01 gsr, running an obd1 computer if that makes any difference.
Anyway, the tach works fine, same as speedo, the two problems im having are:
Once the key is turned to ACC or ON, the temp gauge pegs H, and doesn't move at all. Also, when I turn the turn signal for left, the indicator comes up for the right, and vice versa. When I flash the high beams, the high beam indicator as well as both turn signal indicators illuminate.
Hope this is just a silly bulb issue or something, anyone got some advice?
Old Nov 3, 2006 | 11:51 AM
hybrid98's Avatar
Default Re: Just put in my USDM ITR cluster..weird problems (a1320addict)
what year is the cluster out of?
Old Nov 3, 2006 | 01:11 PM
Default Re: Just put in my USDM ITR cluster..weird problems (hybrid98)
98-01 i believe.
Old Nov 3, 2006 | 06:37 PM
BlueIntegraBoy's Avatar
Put the individual ITR gauges into the GSR housing. And see if that works.
Old Nov 3, 2006 | 07:35 PM
mtpktz.'s Avatar
Default Re: Just put in my USDM ITR cluster..weird problems (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Put the individual ITR gauges into the GSR housing. And see if that works.</TD></TR></TABLE>
Old Nov 5, 2006 | 06:35 PM
Default Re: Just put in my USDM ITR cluster..weird problems (mtpktz.)
got everything working...except the speedo is super off now, it's very delayed..and stutters through the MPH range...any suggestions?
Old Nov 5, 2006 | 06:57 PM
youre_scum's Avatar
Well, I purchased a 96spec JDM ITR cluster for a 99GS, and had similar problems. I switched the green contact film on the back of the JDM cluster with the USDM cluster and every worked perfect. Be very careful thou, the film has been on there for years and looks like it doesnt want to budge, so use like a credit card to separate it from the cluster.I think the only thing I removed before doing this is the light bulbs and all tiny screws securing the green film.
a1320addict
Nov 6, 2006 09:22 AM
diversegsr
Dec 26, 2005 11:16 AM
diversegsr
Dec 24, 2005 10:07 PM
ALLphilthyDC2
Dec 5, 2005 10:34 PM
Comp97GSR
Jun 23, 2002 05:53 PM
