Will a 15x8 +20 fit on a EK?
Old Nov 3, 2006 | 10:53 AM
nonsense's Avatar
Default Will a 15x8 +20 fit on a EK?
Well? will it
I'm looking at two options for 15x8 +20 and +40. I'm thinking the +40 will hit the suspension, but will the +20 stick out past the fenders?
Old Nov 3, 2006 | 12:54 PM
lamsv's Avatar
15x8.5, et11.
pm the owner: EJSlide
Old Nov 3, 2006 | 03:15 PM
ASpecProducts's Avatar
Default Re: (lamsv)
yeah that set up like the picture above will work 15x8.5 +20 and use some 195 tires. you would need to sretch the tires to make it clear fender, even a tiny roll will work.
if u want that compare offsets with this car.
8 +20 to 8.5 +11
you will have 3mm less room on the inside of the wheel to your shock tower,
and your outside of the wheel will sit in 15mm closer from the fender.
Old Nov 3, 2006 | 03:24 PM
Default Re: Will a 15x8 +20 fit on a EK? (nonsense)
if u have a 15x7 +42 now compared to 17x8 +40
u will have 11mm less clearance in the inner side
and u will have EXTEND an extra 15mm for the outer side of the wheel.
Old Nov 3, 2006 | 05:32 PM
nsxtasy's Avatar
H-T Order of Merit
That's too wide for street use. (Unless you're talking about track tires.)
For 15" wheels on your car, you should be getting 195/55-15 or 205/50-15 tires. Those sizes are only approved for wheels that are 5.5-7.0 inches wide.
Old Nov 5, 2006 | 08:16 PM
949Racing's Avatar
Hey Nonsense, bring your EK5 by my shop. 20371 Lake Forest Rd #A4. I have some preproduction 6UL's I need to test fit on Hondas. 15x8 +40 & +20.
Old Nov 6, 2006 | 06:48 PM
Bailhatch's Avatar
Default Re: Will a 15x8 +20 fit on a EK? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
One of the most common civic/integra tires, the Falken Azenis in a 205/50 15 fits perfectly on a 15 x 7.5" wheel and looks the best IMO.
http://www.falkentire.com/rt615_sizes.html
Old Nov 6, 2006 | 07:26 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will a 15x8 +20 fit on a EK? (Bailhatch)
As you can see from the specs, the Azenis RT-615 isn't approved for mounting on a 15x8 wheel, either.
Old Nov 6, 2006 | 07:34 PM
Bailhatch's Avatar
that's true
Old Nov 7, 2006 | 09:47 PM
nonsense's Avatar
I stopped by the shop and tried on a few pairs of shoes. The bottom line is that the +40s are barely too close in the back and touch the UCA at the trailing arm. I think a 3mm spacer would be enough for them to clear. Rolling the rear fenders would be needed. The fronts seem to fit nicely with a 225/45-15 Hankook tire
15x8 +40 225/45-15:
Just for ***** and giggles we put on a +20 with a 245/40 tire!
Pics of the various colors:
Silver:
Black w/polished lip (kinda hard to see in this pic):
Nickel:
Old Nov 8, 2006 | 02:00 AM
tr1plesix.'s Avatar
I hope those aren't the wheels you are trying to buy
Old Nov 8, 2006 | 06:32 AM
nonsense's Avatar
Default Re: (tr1plesix.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr1plesix. &raquo;</TD></TR><TR><TD CLASS="quote">I hope those aren't the wheels you are trying to buy </TD></TR></TABLE>
Why's that. Can you explain?
Old Nov 9, 2006 | 02:51 AM
Peter Shen's Avatar
Default Re: (nonsense)
hehe i think it looks great! i'm running 16x7 +35 and i've been wondering for the longest time about fitment for 16x8 on my EK
thanks for the pics
billybobman805
Aug 7, 2018 03:33 AM
Bleakened
Mar 12, 2018 03:31 PM
gummybear
Feb 4, 2009 10:50 PM
nickohlassss
Aug 24, 2008 05:42 PM
MS14
Apr 23, 2004 06:40 AM
