Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
No low beams on 01 crv
Old Nov 3, 2006 | 08:46 AM
cpierich's Avatar
Default No low beams on 01 crv
Okay i got a 2001 crv that the both low beams just stoped working, high beams work fine tho. Does anybody know what might be the problem? I checked all fuses,swaped out the headlamp relays under the hood as well as the bulbs and nothing still. I even metered the headlight wires in a couple spots and I was getting power with the low beam swith on. I'm stumped!!!
Old Nov 4, 2006 | 03:10 AM
Ross 2.0's Avatar
In a Junkyard near you.
i'm getting to you but it's not going to be till monday before i can give you a real responce. PM me if you don't get one by lunchtime monday. (you'll need to make some posts first)
Old Nov 4, 2006 | 04:14 AM
golf's Avatar
Default Re: No low beams on 01 crv (cpierich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpierich &raquo;</TD></TR><TR><TD CLASS="quote">Okay i got a 2001 crv that the both low beams just stoped working, high beams work fine tho. Does anybody know what might be the problem? I checked all fuses,swaped out the headlamp relays under the hood as well as the bulbs and nothing still. I even metered the headlight wires in a couple spots and I was getting power with the low beam swith on. I'm stumped!!!</TD></TR></TABLE>
When you were checking for power (test light or multimeter ) you were likely using the chassis as ground.
If you were getting 12 volts up to the socket then likely the problem is a faulty ground connection for lamp circuit itself. Meter the ground wire from the lamp socket to check for continuity.
Old Nov 4, 2006 | 10:35 AM
cpierich's Avatar
Default Re: No low beams on 01 crv (golf)
yeah I was, I didn't even take that into consideration. I'll have to look at it again if its not already at the honda shop. My friends wife works two jobs so she needed it fixed asap, but I know how the shop is about gettin things done on the weekend. Thanx for the reply.
Old Nov 6, 2006 | 09:27 AM
cpierich's Avatar
Default Re:
Okay found out it was the light swich, smelled like something burnt inside the car and thats what it was.
Old Nov 9, 2006 | 07:29 AM
jz98ctr's Avatar
i was gonna say tha switch
u beat me to it
powerwagon340
Honda Civic (2001 - 2005)
Dec 24, 2008 01:07 PM
zaratecivic
Mar 8, 2008 08:07 AM
CivicVelox17
Jan 2, 2007 10:11 PM
em2_blk_01
Sep 28, 2006 12:33 PM
Jacen
Mar 22, 2006 10:51 PM
