will this remove my valve springs??
http://buy1.snapon.com/catalog...11149
wil this work for removing my valve springs... i am having a hell of a time firguring this out on my own
the head is off the block right now
so is there a better one to get to use with the head off the BLOCK?
Modified by rewerbcrx at 1:22 PM 11/3/2006
I know that there a lot of threads with this topic and i have been looking through them...
the real question is... the EASIEST route without spending over 100 dollars for the freaking tool... something that will ork with the head off the block... if there is no such tool then one with the head on
please list for me thanks...
I wouldn't waste your money. Look in your tool box and get a 16MM or so and a hammer and start smacking. It doesn't take much. If you are getting the head machined by a pro then pop them yourself.
If you plan on re-installing everything yourself then the purchase would be worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">so is there a better one to get to use with the head off the BLOCK?
Modified by rewerbcrx at 1:22 PM 11/3/2006</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doodoo »</TD></TR><TR><TD CLASS="quote">I wouldn't waste your money. Look in your tool box and get a 16MM or so and a hammer and start smacking. It doesn't take much. If you are getting the head machined by a pro then pop them yourself.
If you plan on re-installing everything yourself then the purchase would be worth it.</TD></TR></TABLE>
That is what I did to mine.
Just keep a look out for those keepers...
I think Autozone might have a loan - a - tool for that job... not sure..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">just go to Harbor Freight and get their $8 VS compressor. cheap and works like a charm
i purchsed a normall everyday compressor the problem between teh v8 compressors and the honda ones is that the honda valve springs are sitting inside the head where teh v8 ones aren't
</TD></TR></TABLE>i purchsed a normall everyday compressor the problem between teh v8 compressors and the honda ones is that the honda valve springs are sitting inside the head where teh v8 ones aren't
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR »</TD></TR><TR><TD CLASS="quote">
I think Autozone might have a loan - a - tool for that job... not sure..</TD></TR></TABLE>
i tried advance auto already adn they only have the c clamp looking deals that only work on 6 and 8 cycl. heads with the valve springs that set up from the head not down inside it... i am not looking to just take teh springs off but to put them back on as well...
i purchsed a normall everyday compressor the problem between teh v8 compressors and the honda ones is that the honda valve springs are sitting inside the head where teh v8 ones aren't </TD></TR></TABLE>well, i have the HF one. ive disassembled several heads so far with it and had no issues. its cool if you want to spend more though...
i just looked at the one you suggested it looks like that might actually work! i will buy it and check it out....
is there anything that i should know when using it?
Make sure to keep pressure in the cylinders when you start removing the springs.
Most overhead valve spring compressors will do the job and so will the 16mm socket but it isnt the best option. If you have the money buy the snap on one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx »</TD></TR><TR><TD CLASS="quote">i just looked at the one you suggested it looks like that might actually work! i will buy it and check it out....
</TD></TR></TABLE>one thing...
the tabs at the end of the arms that actually grab the springs need to be grinded a tad. they are too thick to fit into the spring, so you just need to make them a little thinner. you will see what i mean when you get it. VERY simple
I didnt grind anything. I used this tool and I still have it. Only thing that sucked is that I had to have a firend help me.
This tool under the link below is great and Only requires one person. I have used both but I ended up[ buying the naop on tool before I saw this one.
http://cgi.ebay.com/ebaymotors...ZWDVW
i bought that one so i will test use it and see what happens...
does it come with instructions... if not could you take a pic of you using it... so i can see... like my signature says .... its my first build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx »</TD></TR><TR><TD CLASS="quote">here's mine. the actual tabs that grab the spring on the bottom is what i was talking about grinding. it works perfect
Beer and wrenching
</TD></TR></TABLE>Beer and wrenching
