Honda S2000 Honda S2000
ABS bypass?
Old Nov 3, 2006 | 08:21 AM
TL1000R's Avatar
Default ABS bypass?
Has anyone out there ever bypassed the ABS system on their car? If so, what is the best way to do it so the ecu doesn't throw a trouble code?
Old Nov 3, 2006 | 09:41 AM
gomarlins3's Avatar
Why would you want to do that?
Old Nov 3, 2006 | 10:15 AM
TL1000R's Avatar
Default Re: (gomarlins3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gomarlins3 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to do that?</TD></TR></TABLE>I just recently got into an accident with someone who pulled out in front of me and if I'd been able to lock up, I would have saved my car. Instead, it locked up momentarily and then just rolled into them. Caused over 5K damage to my S and several weeks in the shop. Every rwd car I've ever owned haven't had ABS and never had that type of accident. Therefore, I want to disconnect the ABS system. Leave it present, but inopperable.
Old Nov 3, 2006 | 02:57 PM
Enthalpy's Avatar
Default Re: (TL1000R)
static co-efficient of friction (when the tire is rolling) is greater than sliding co-efficient of friciton in ALL cases. this means that when the tires keep rolling they have WAY more grip than skidding. your car stops quicker with ABS than when you jack the brakes and lock all four up and slide. dont pull your ABS. there is a reason it is banned from many forms of racing...because it works!!!
Old Nov 5, 2006 | 09:24 PM
Weifast's Avatar
Default Re: ABS bypass? (TL1000R)
Yea...I'd keep it if I were you...for reasons stated above.
Old Nov 6, 2006 | 05:01 PM
odortiz's Avatar
Default Re: ABS bypass? (Weifast)
if you pull the abs fuse, it will be disabled. not a good idea on the street.
threshold braking stops faster than ABS, but it's a skill that takes lots of time and practice to perfect and make instinctual. the hardest part of it is learning how fast you can transition from rolling to full braking without tripping ABS.
had you locked up, there is a strong chance the damage would have been worst.
Old Nov 6, 2006 | 06:39 PM
Petey_S2K's Avatar
plus, S2000 was designed with ABS for it, so maybe the S2000 isn't designed to run without ABS? so might not be a good idea.
Old Nov 6, 2006 | 11:08 PM
evil vapor's Avatar
Default Re: (Petey_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petey_S2K &raquo;</TD></TR><TR><TD CLASS="quote">plus, S2000 was designed with ABS for it, so maybe the S2000 isn't designed to run without ABS? so might not be a good idea. </TD></TR></TABLE>
the brake system works with or without the abs pump engaging at lockup.
Old Nov 8, 2006 | 08:56 PM
iam7head's Avatar
Default Re: (evil vapor)
I know what is the OP's talking about, although i am not saying the car will stop faster with or without the ABS. almost all the car with abs will stop a tad longer, almost all car.(my generation of accord for example)
it just a simple question, i don't know why everyone's jacking his nuts, the op is not messing with your ABS.
yeah, take out the abs fuse and that should disable the pump, i track my car all the time with the pump disabled, i can brake better without the abs unit after my shared of square tires
not for everyone, yes, but i know alot of track guy perfer without abs(like me)
Old Nov 13, 2006 | 12:34 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
im sorry...but if you think that you would have stopped faster had you locked up your tires, you're very very mistaken. ABS will stop you faster than locking up your tires in all cases. Threshold braking will stop you faster than ABS, but how many people threshold brake when they're going to plow into the back of a truck or something? Most people just jam the brakes down. leave your ABS on. For the track or the street. Modern ABS systems allow you to stop MUCH MUCH shorter than cars without.
Old Nov 13, 2006 | 06:12 AM
Sean Juan's Avatar
Default Re: ABS bypass? (B serious)
ABS is there for a reason. Honda wouldn't put something on the car to make it less safe and brake worse. Next time give yourself more room when following. I doubt someone pulled out in front of you because if that were the case, you would be more interested in having a post ranting about how people should learn to drive rather than taking out your abs...
Old Nov 13, 2006 | 07:41 PM
iam7head's Avatar
Default Re: ABS bypass? (sean@springrates)
it's a damn simple question and i don't know why alot of you guys still have to preach to this.
so here we go, straight from honda's owner manual
"Abs does not reduce the time or distance it takes to stop the car, it only help with steering control..."
yes, no, maybe?
just to say this one more time, the OP isn't about to mess with YOUR abs pump so..yeah
Old Nov 14, 2006 | 07:13 AM
Mr. Projekt's Avatar
* B A N N E D *
I think theres more than just the ABS motor. There's the 4 wheel speed sensors that connect to the ECU; the ABS runs off of that. If you pulled the ABS fuse, you'd be OK until you actually cross that threshold where the ECU would call for ABS, then the light would be triggered.
thegeezerkid
Jun 18, 2008 10:24 PM
rdeezy78
Apr 16, 2007 03:40 PM
Fink2iCe
Feb 28, 2005 08:07 PM
Honda_NOLA
13
Oct 18, 2004 12:34 PM
Tommy_Gunns
May 20, 2003 11:18 AM
