what else should i upgrade on my dc2???????
Old Nov 2, 2006 | 10:00 PM
delko's Avatar
Default what else should i upgrade on my dc2???????
i already have i/h/e. my car is non vtec and i want to go hit 13's all motor. what can you suggest?
Old Nov 2, 2006 | 10:43 PM
qfast817's Avatar
Default Re: what else should i upgrade on my dc2??????? (delko)
it will take alot of money to do all motor and a lot of tuing time. your better of boosting but look in to resleving cost and a new set of pistons
Old Nov 2, 2006 | 10:48 PM
Sack Master's Avatar
Default Re: what else should i upgrade on my dc2??????? (qfast817)
Correct me if I'm wrong but wouldn't a DC2 have vtec(gsr/type-r)?
Old Nov 2, 2006 | 10:49 PM
Fat Chick Magnet's Avatar
no cat, ctr pistons for higher compression unless you want to go lower and turbo your car, ctr intake cam w/ itr exhaust cam, dual valve springs, etc
Old Nov 2, 2006 | 11:48 PM
martyball619's Avatar
Default Re: what else should i upgrade on my dc2??????? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong but wouldn't a DC2 have vtec(gsr/type-r)? </TD></TR></TABLE>
yup!
Old Nov 3, 2006 | 06:45 AM
95 integra's Avatar
Default Re: what else should i upgrade on my dc2??????? (DC2SiR)
13s all motor......ls/vtec + high compression + cams FTW!!!
Old Nov 3, 2006 | 11:40 AM
doood's Avatar
been there done that
crower 404 cams, valvetrain , p30 pistons, and tuning. if that doesnt get you there just spray the bitch.
Old Nov 3, 2006 | 11:48 AM
95 integra's Avatar
Default Re: what else should i upgrade on my dc2??????? (sticky icky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">crower 404 cams, valvetrain , p30 pistons, and tuning. if that doesnt get you there just spray the bitch.</TD></TR></TABLE>
Go ahead and get the spray ready....or strip the car down to the 2,000lb mark.
Old Nov 3, 2006 | 10:05 PM
davidluko's Avatar
An N/A setup, especially on the non-vtec, is usally a waste of money IMO. I'd suggest putting a turbo on and running 9-10 psi on a good tune with an Si or ITR tranny.
Old Nov 3, 2006 | 11:01 PM
veryslowIntegz's Avatar
DC4!!!
Old Nov 4, 2006 | 04:10 AM
no2unenolife's Avatar
spray!
Old Nov 4, 2006 | 05:24 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: what else should i upgrade on my dc2??????? (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote"> Si or ITR tranny.</TD></TR></TABLE>
Why no love for the GSR tranny?
Old Nov 4, 2006 | 11:33 AM
Leo C's Avatar
Night Owl
Your LS trans. is killing you. Swap that out for a GSR, ITR, b16 tranny. Then move on to p30 pistons, cams and a good tune. Also consider some form of forced induction if you are serious about modding your car.
Old Nov 4, 2006 | 11:37 AM
mrdeadman's Avatar
They let me pick
ls/vtec is a start.
Old Nov 4, 2006 | 12:17 PM
riceball777's Avatar
Default Re: (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">An N/A setup, especially on the non-vtec, is usally a waste of money IMO. I'd suggest putting a turbo on and running 9-10 psi on a good tune with an Si or ITR tranny.</TD></TR></TABLE>
best advice ever
i speak from expearance
a built all motor b seris in a full weight integra will not be fast at all
Old Nov 4, 2006 | 01:15 PM
-Championship-'s Avatar
76.169.175.137
Default Re: (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
best advice ever
a built all motor b seris in a full weight integra will not be fast at all</TD></TR></TABLE>
i second that, but the man asked for an all motor answer
here you go
s4c tranny
crower 404 cams
valve train
cam gears
FPR
F & S clutch (6 puck)
9lbs flywheel
AEBS or blox skunk manifold
bored to 85mm
arias 11.2 comp pistons
eagle rods
smsp or good ol randy header (open)
with good tires (nito, falken)
and hell of a luanch
it is possible but well NOT worth the effort time and money
Old Nov 4, 2006 | 01:21 PM
sumyungguy's Avatar
Default Re: (CW_98gsr)
Suspension!!!!!!
Check my Sig
Old Nov 4, 2006 | 02:03 PM
coronadrinker's Avatar
turbo would probably be the easiest/cheapest way to break into the 13's
Old Nov 4, 2006 | 02:04 PM
Got Utensils's Avatar
Default Re: (sumyungguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumyungguy &raquo;</TD></TR><TR><TD CLASS="quote">Suspension!!!!!!
haha.
Old Nov 4, 2006 | 02:06 PM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delko &raquo;</TD></TR><TR><TD CLASS="quote">i already have i/h/e. my car is non vtec and i want to go hit 13's all motor. what can you suggest?</TD></TR></TABLE>
Driver....hahahaha!
Old Nov 4, 2006 | 06:30 PM
doood's Avatar
best advice ever
tell that to b19coupe who ran a 12.8 in his 2600lb integra with 'built' b series
Modified by that one doood at 3:42 AM 11/5/2006
Old Nov 4, 2006 | 06:53 PM
sumyungguy's Avatar
Default Re: (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">tell that to b19coupe who ran a 12.8 in his 2600lb integra with 'built' b series
I bet he had good suspension too
Check Sig
Old Nov 4, 2006 | 08:27 PM
BrianZ's Avatar
Take all the weight out of the car you car (sunroof, interior, windows, etc).
Old Nov 4, 2006 | 08:35 PM
Robstunner4's Avatar
Default Re: what else should i upgrade on my dc2??????? (BrianZ)
nonvtec =/= DC2
Old Nov 4, 2006 | 09:59 PM
sumyungguy's Avatar
Default Re: what else should i upgrade on my dc2??????? (Robstunner4)
I like Brian's idea
