How to distinguish between trims - si dx std hf?
Old Nov 2, 2006 | 08:33 PM
drumminforev's Avatar
Default How to distinguish between trims - si dx std hf?
Im buying this 88 crx automatic from this guy. He says he thinks its an hf...but i was pretty sure that hf didnt come in automatic...so
Do HF come in automatic?
And regardless, how do i tell what trim the car is? Fast replies appreciated since im buying this car tomorrow! Thanks!
Old Nov 2, 2006 | 08:39 PM
crx2nr822's Avatar
Default Re: How to distinguish between trims - si dx std hf? (drumminforev)
Of course check the obvious, the back corner piece to see if it says HF.....also check the motor and see if the motor is DPFI or MPFI, the HF is a MPFI......and you can also check if the catalytic converter is in view (it is pretty much the bottom piece of the HF header) which would be another sign of the HF.....
Old Nov 2, 2006 | 08:42 PM
Default Re: How to distinguish between trims - si dx std hf? (crx2nr822)
The MPFI would be on the intake manifold right.
It says it has replaced exhaust so any other way to verify?
Old Nov 2, 2006 | 08:48 PM
E_F_9's Avatar
https://honda-tech.com/zerothread?id=650219
Old Nov 2, 2006 | 09:26 PM
Bob_760's Avatar
Default Re: (E_F_9)
to answer your question only DXs came with the option for atx so theres your answer...
http://www.stefanoparis.com/cr...e.htm
Old Nov 3, 2006 | 05:31 AM
harmonator84's Avatar
Default Re: (Bob_760)
This has been asked hundreds of times. All you had to do was search. But yes it is a DX. Good luck.
justin1785
21
Jun 29, 2010 10:23 AM
5litereater
Jun 24, 2004 06:01 PM
NightHawkC5
Feb 22, 2003 07:05 AM
iwouldHITit
Dec 8, 2002 11:46 AM
bluebullet
10
Jun 16, 2002 06:58 PM
