Suspension & Brakes Theory, alignment, spring rates....
Knocking while driving and greese wheel? HELP!
Old Nov 2, 2006 | 09:39 AM
Civichatch2k's Avatar
Default Knocking while driving and greese wheel? HELP!
Ok, well i have now replaced both axles and they are not torn or anything. Both axles appear to be in good condition.
I can not find a whole in any of the boots but I have grease on my passenger wheel and on the back of the hub. I have cleaned the majority of it off and Have not notice any mor on the suspension but I have found it on the wheel.
When I am turning left or right I hear the noise. I would like to know if it is a possible wheel bearing and if so would they put off greese like that?
The wheel bearings have never been replaced and the hubs are from like a 97 or older del sol. The car is a 00 hatch. Just need some info.
Thanks.
Old Nov 2, 2006 | 10:07 AM
Relic1's Avatar
could be your axle nut needs to be tightened. That will allow the bearing/hub to seperate a little and cause the noise. All though it shouldn't cause the grease.
nipcup101
Jul 20, 2009 05:17 PM
Brewer
Suspension & Brakes
18
Aug 20, 2006 09:19 AM
sicivic
May 7, 2004 06:05 AM
fe519
May 19, 2003 07:29 PM
whatcivic
Jul 24, 2002 09:38 AM
