94 Accord EX Problem....
Old Nov 2, 2006 | 06:20 AM
jdm94accord's Avatar
Default 94 Accord EX Problem....
just recently my dashboard has been acting up.....the switch above the cold/hot **** that lets you either circulate the air or just use air from outsside has been acting up. Once i shut my car off and take the key out the light stays on, not sure what the problem is and how i go in fixing it, its just annoying and i dont know if it will drain my battery(hopefully not) anyone have any ideas on what it is or how i should fix it?
Old Nov 2, 2006 | 02:21 PM
wrsimmons21's Avatar
Default Re: 94 Accord EX Problem.... (jdm94accord)
Ignition switch can affect many things turning on or off on a car. My guess is you need to replace it.
Old Nov 2, 2006 | 09:37 PM
ex95cord's Avatar
ive never had problems with my interior, but you can get to the back of that panel pretty easy to check connections.
its just a small LED so I seriously doubt it will drain your bat either, so dont worry till you get it fixed. it might be easiest to just replace that button....?
pinggoy
Jul 4, 2009 02:50 PM
integrajerzey
Apr 7, 2009 03:50 AM
hatch120
Apr 15, 2008 05:55 PM
BoostedH23Accord
Nov 29, 2006 07:12 PM
90babyblue
Dec 30, 2005 06:57 PM
