HELP my civic acting like a mustang 30 mpgs to 20
Old Nov 2, 2006 | 12:43 AM
Savegascivic!'s Avatar
Default HELP my civic acting like a mustang 30 mpgs to 20
Hello I have a 98 civic ex and I recently had some parts fixed at the mechanic the engine kept on like jerking when changing gears sometimes it would redline then change gears (my car auto) so i got that fixed i don't know what they did. they also tried to fix my engine when it was on the thing would shake so bad it made this noise sounded like i was a train like a CHung CHUG CHUG sound. they didn't fix the train sound though kinda just dulled it.
to get to the point i noticed my civic is not getting the 30 mpgs it used to get its getting like 20mpgs anyone know why?
and how big is an ex tank? like 8-9 gallons?
Old Nov 2, 2006 | 12:53 AM
BUMP FOR A NOOB LIKE ME
Old Nov 2, 2006 | 12:59 AM
Bunger's Avatar
Default Re: (Savegascivic!)
Any ECU codes?
Old Nov 2, 2006 | 01:16 AM
ohh yeah thats what i forgot to metion my engine light was on then i went to my mechanic and he turned it off somehow then it came back on like the next day
Old Nov 2, 2006 | 01:19 AM
Bunger's Avatar
He probably just reset the codes. Do you have, or know anyone that has a code reader? Quick and easy way to pull the codes through the OBD-II port. If it took a day for the light to come back on, its probably a sensor out of spec... not something completely broken. The best place to start is to see what your codes are.
Old Nov 2, 2006 | 12:10 PM
Default Re: (Bunger)
nope i dont i guess ill just have to bring it back to the mechanic or somin
Old Nov 2, 2006 | 12:27 PM
Steri's Avatar
Default Re: HELP my civic acting like a mustang 30 mpgs to 20 (Savegascivic!)
Well first off you should post this in the right forum. This forum is for older cars. But I know that on your car there is a plug that you can jumper near the ecu that will flash the check engine light giving you a number that you can then check against a chiltons or helms manuals list of obd-II codes. Then you can figure out whats wrong.
Try posting here with your problem
https://honda-tech.com/zeroforum/1
Old Nov 2, 2006 | 01:38 PM
Default Re: HELP my civic acting like a mustang 30 mpgs to 20 (89EF_Sleeper Si)
AHH THANKS im new to this place as you can tell
slang6
Honda Civic (2001 - 2005)
Apr 23, 2018 10:12 AM
wonderwhy7
Jul 5, 2017 01:54 PM
Savegascivic!
Nov 4, 2006 02:17 PM
mushu315
Jun 3, 2005 06:58 PM
Khmai_guy
May 2, 2004 11:56 AM
