Question: 97gsr into a 98ex will it be plug and play?
Old Nov 1, 2006 | 11:29 PM
intrnsik's Avatar
Default Question: 97gsr into a 98ex will it be plug and play?
Will a 97gsr, which is obd2a I believe, be plug and play for a 98ex which is also obd2a, correct? So if I have my information correct it should be plug and play and I wouldn't need any jumper harness nor have to change the dizzy and what not. Can somone please confirm this. Any advice would be appretiated. Thanks in advance
Old Nov 2, 2006 | 07:40 AM
b16a27's Avatar
Default Re: Question: 97gsr into a 98ex will it be plug and play? (intrnsik)
yea it is
Old Nov 2, 2006 | 09:21 PM
intrnsik's Avatar
Default Re: Question: 97gsr into a 98ex will it be plug and play? (b16a27)
Thanks man, hoping to do a swap soon.
Old Nov 3, 2006 | 05:58 AM
EE_Chris's Avatar
You still have to add/modify some wires...
Old Nov 5, 2006 | 02:24 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Question: 97gsr into a 98ex will it be plug and play? (EE_Chris)
you'll have to add the wiring for IAB
Old Nov 6, 2006 | 09:10 PM
allmotorabe's Avatar
use the harness form your civic and get the jumpoff harness it rums better obd1
you cant use the gsr harness on the ek the plugs are different
Pancho2193
Nov 24, 2012 10:02 PM
shadytreeworks
Apr 5, 2009 07:32 PM
neutron91
Feb 18, 2004 07:23 PM
Wazup
May 6, 2003 10:03 PM
