Swapping a K20A (RSX TYPE S) into a '94 Integra
Old Nov 1, 2006 | 07:09 PM
tk26's Avatar
Default Swapping a K20A (RSX TYPE S) into a '94 Integra
I am buying a '94 Integra and am planning on swapping in a new more powerful engine, I am hoping to swap in a B18C (Type R) engine but am wondering how much harder it would be to swap in a K20A (Type S) instead. I know with civic's it is a much more expensive and difficult swap is it the same for a '94 Integra. Has anyone do this swap? or even the B18C swap that can give me an pointers or feedback on these swaps.
Old Nov 1, 2006 | 07:52 PM
95 integra's Avatar
Default Re: Swapping a K20A (RSX TYPE S) into a '94 Integra (tk26)
92-95 Civics are the same chassis design as the 94+ Integras and the 96-00 civics arent that much different. B-series bolt directly up, k-series require special mounts, axles, exhaust and I believe you have to run the K-pro. There should be alot of info on the swap in the hybrid section.
Old Nov 1, 2006 | 08:01 PM
mtpktz.'s Avatar
Default Re: Swapping a K20A (95 integra)
First, if you are interested in swapping a K20, I'll lead you here: http://www.k20a.org
Now, B series are definately a lot easier to swap than the k20. In the end, you WILL spend more money on the K series, however the K series are outstanding motors.
The K series requires a lot of extra things such as - Mounts, tranny (obviously 6spd), and lots of various little things.
Head over to k20a.org and do some research.
Old Nov 1, 2006 | 08:06 PM
aaronISthrowed's Avatar
Default Re: Swapping a K20A (mtpktz.)
K swap would be badass but alot more work than a B18C5 swap.
ct.vxHatch
51
Jul 18, 2010 09:59 AM
StrictlyJdm94
May 30, 2005 07:13 AM
currly1609
Acura TL, RL & ZDX
Dec 7, 2004 12:33 PM
helzbelz101
10
May 6, 2004 05:59 AM
