baessy noise and engine vibration
my Gasket blew and started to overheat
then engine head shaved and installed by local shop - same time Timing belt and balancer belt also replaced - ooh I have new Rad, thermostat too.
engine vibration and VTEC error code 22
I cleaned the vtec solenoid - so far no code 22 check engine light.
but engine vibration: man my whole driving cabin is vibrating - I check all engine mount looks fine (but I don't know if they work or no) how can I check them.
my Cat doesn't have a cat cover - so don't worry about it.
I also remove every thing and check the Timing and Balancer belt they are perfect.
this happened as soon as I let go my gas paddle
at this point I don't have clue - what to look for. my Helms Manual not saying anything about baessy sound and vibration.
help me if you can and have time.
Thanks in Advance
ujhonda
Thanks in Advance
ujhonda
my pcv valve was the culprit. put your finger on or pop it out and see if that's it.
I replaced it, but it still does it. I suspect something else. My vacuum test showed 22 Hg which is good according to the manual. Anybody got any clues? I replace the airfilter, but still no love.
Darkshowdo
Sep 8, 2009 12:12 AM
benji7288
Mar 19, 2009 04:48 PM
