What aftermarket high end header will fit with stock crossmember?
Old Nov 1, 2006 | 05:39 PM
specie's Avatar
Default What aftermarket high end header will fit with stock crossmember?
I'm building another Crx. It's been a while since I sold my ls/vtec Crx and I just got another '91 Si.
I'm using Arizona Race mounts, gsr block (ls crank) with b16 head.
I currently have the DC Race header (not the jdm but the one with the burns collector). I had a jdm itr on my old crx and I had to notch quite a bit of the crossmember off.
Does anyone have a SMSP, ANR, or Toda using the stock crossmember?
Old Nov 1, 2006 | 05:46 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: What aftermarket high end header will fit with stock crossmember? (specie)
I am about to be stickin on an Edlbrock with the 2.5 mod on with stock X member, should be an insanely unfun install..
May I ask why you don't want to swap out the X member?
As far as anything bigger like a RMF SSMP BISI header i've not seen it done with stock X member.
Old Nov 1, 2006 | 05:49 PM
Tippyman's Avatar
4-2-1 usually fit with less trimming then a 4-1.
Old Nov 2, 2006 | 07:03 AM
Suck my DX's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">4-2-1 usually fit with less trimming then a 4-1.</TD></TR></TABLE>
do you mean a stock unmodified xmember? good luck cuz its not gonna happen...i had to hack the stock crossmember like crazy and even had to grind about a quarter inch out of my block webing for my rage header to clear
the anr compact is nice, but i think you still need to mod/swap the xmember...the motor sits pretty low,theres not much room to work with
Old Nov 2, 2006 | 07:26 AM
Furyof4's Avatar
Default Re: (Suck my DX)
A Toda would probably fit with little/no trimming.
ryanangelo212
May 29, 2009 07:01 AM
hfsullivan
Nov 15, 2007 05:11 PM
K.Quinn
Jun 22, 2006 10:39 AM
tygsr
10
May 25, 2006 04:33 PM
88 rex
Jul 9, 2005 04:29 PM
