ANYONE have experiance with the new MOROSO AXLES?
Old May 6, 2002 | 04:26 PM
Erik_Pb_Foot's Avatar
New User
Default ANYONE have experiance with the new MOROSO AXLES?
OK, the new Moroso axles.... anyone have them yet or know much about them? I'm positive once I bolt the bogart & wrinkle walls on my axles are just going to snap to bits and pieces.... i wanted to know where I can get these axles and if any other companies out there have comperable axles. Also, what kind of guarantee do these have? Thanks
-Erik <---- Who saw these on The Speed Channel
Old May 6, 2002 | 08:52 PM
New User
Default Re: ANYONE have experiance with the new MOROSO AXLES? (Pb_Foot)
somebody?
Old May 6, 2002 | 09:34 PM
slowerthanu's Avatar
New User
I heard they are somewere in the neighborhood of $2000. I heard they are excellent though.
Old May 7, 2002 | 01:50 PM
MrFatBooty's Avatar
www.driveshaftshop.com
Their site's a bit tedious to navigate but if you give em a call they should be pretty helpful.
Old May 7, 2002 | 03:58 PM
New User
Default Re: ANYONE have experiance with the new MOROSO AXLES? (MrFatBooty)
Yikes, still looking for an exact price for the Moroso's but the DSS wants $1,600 for their strongest axles!!!!! I think if I was gonna spend that much I would stick with Moroso. I know they aren't going anywhere. here's the info on the axles most comperable to the Moroso axles....
Extreme stage 5 solid torsional axle/hub combo reserved for those who have 600hp or more and are tired of broken axles. Extensive research has lead us to this new break thru in axle technology.
non abs style hubs 4 lug-------- $1499.00
abs style hubs 4 lug-------------$1599.00
abs style hubs 5 lug (type r)----$1699.99
the reference to abs and non abs is
because Honda and Acura have different wheel bearings for the systems. to properly order you axle/hub combo be sure to know if your spindle is from a abs or non abs car. The new stage 5 axles
preceed the stage 4 units that were having some trouble with 28" and larger tires. The new stage 5
units are made from a material called 300M that is by far the strongest material that could be used in this application. The axles are special due to our unique approach to the heat treat and temper of this product. After serious consideration of how to do this we came up with a furnace heat treat with a liquid salt bath quench. then we have a special double temper, to give the axle the extra fatigue cycle you would expect from a pair of high dollar axles. these units are made in limited quantities and the best axles to date.
Just like all axles we make these can be made to
any length spec. along with any custom hub.
aj_scribble
Apr 24, 2008 06:39 PM
TypeRod
Aug 21, 2002 10:48 PM
