WTF is this peice called FTW
Old Nov 1, 2006 | 01:44 PM
Robstunner4's Avatar
Default WTF is this peice called FTW
i think i have coolant leaking from the little 3/8's inch or w/e 90 degee fitting. just wanted to know what its called.
Old Nov 1, 2006 | 03:01 PM
thesmogman's Avatar
Default Re: WTF is this peice called FTW (Robstunner4)
Bleeder screw.
Just wrap the threads with some teflon tape or use some RTV.
When you loosen it coolant will come out the little hole, but not when tight.
It's also 12mm.
Old Nov 1, 2006 | 06:08 PM
Default Re: WTF is this peice called FTW (thesmogman)
no not the screw. the whole assembly. its all one peice. theres 1 upper rad hose that goes into it, and 1 smaller coolant hose that goes to the TB
Old Nov 1, 2006 | 06:32 PM
Runnerdown's Avatar
its called a water neck, or water outlet. what part is leaking exactly? where the little hose slides on?
Old Nov 1, 2006 | 07:04 PM
ftnjun2x's Avatar
You can figure out how to stop that leak.
Old Nov 1, 2006 | 07:25 PM
GenIIIMrDuece's Avatar
Default Re: WTF is this peice called FTW (ftnjun2x)
jb weld
Old Nov 1, 2006 | 07:27 PM
Default Re: WTF is this peice called FTW (Runnerdown)
water neck indeed!
it might be leaking from the 3/8's elbow fitting
BadassEFdriver
Jun 20, 2011 06:12 PM
zdizzle
Mar 10, 2008 10:50 AM
screen_name
Apr 30, 2005 05:54 PM
Paprika
Dec 21, 2004 04:51 AM
