Is it possible to have a throttle body that is too big?
Old Nov 1, 2006 | 10:53 AM
Kyoto now's Avatar
Default Is it possible to have a throttle body that is too big?
Basically I'm just curious if a larger aftermarket TB would affect driveability negativley. Is it possible to go too big? does it depend on the size of the motor? What kind of gains could be expected? Thanks
Old Nov 1, 2006 | 11:13 AM
Pee Wee's Avatar
Default Re: Is it possible to have a throttle body that is too big? (DA9 Purist)
yes
Old Nov 1, 2006 | 11:14 AM
Kyoto now's Avatar
Default Re: Is it possible to have a throttle body that is too big? (Pee Wee)
could you explain why?
Old Nov 1, 2006 | 11:15 AM
ejmatzell's Avatar
yes... too big and it won't match your intake manifold. it's a pointless upgrade unless you have some head work (like upgraded cams), and an intake manifold. i believe anything aftermarket will be too big.
Old Nov 1, 2006 | 11:47 AM
95 integra's Avatar
Default Re: Is it possible to have a throttle body that is too big? (ejmatzell)
Yes, it will kill your intake velocity....which kills off the ramming effect of incoming air. It will also make your throttle response and low end power bite the dust as well. From what I've seen a 62-64mm is perfect for upwards of the 220whp mark....past that and you might go bigger, but anything bewteen 170-220 is going to be in that range and anything under 170 needs the stock 60mm.
Old Nov 4, 2006 | 07:38 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: Is it possible to have a throttle body that is too big? (95 integra)
It all depends on your setup/Tune.
Basically a throttle 68mm tb will compliment some good head work such as cams, porting and a larger IM
Ill give you an example
Im running a Built 1.8 Lsvtec with a 68mm TB
Buddys Running a built 2.0 Ls Vtec with a 70mm TB
with a stock B16/GSR you could pick up a few hp from a TYpe R TB or even porting the stock one...........
Like we say to the mustang guys bigger is not always better!
itr1244
Jul 9, 2018 06:33 PM
importlvr
11
Dec 11, 2008 03:23 PM
ohsnapzafingcu
14
May 24, 2007 08:58 AM
brand_NOOBian
Mar 31, 2007 04:43 PM
teri_vti
17
Nov 2, 2006 07:24 PM
