1995 honda accord engine troubles
if your rpm drops below ~750 when it starts shaking, then check your throttle cable, egr valve and vacuum lines. If that is not it, then check IAC/O2 sensor.
If it does not drop below ~750 then it may be your front/rear mount.
If it is bogging on acceleration, then check fuel filter/o2 sensor.
which motor do you have or what model of accord?
could be balance shaft belts? I guess it would help if we knew how hard it was shacking. Rememeber its only a 4 banger not a V8...it shakes at idle
Tyler5451
Nov 6, 2017 09:52 AM
mizzolini
May 2, 2008 06:06 PM
OpTiMo MoToR
May 19, 2005 08:14 AM
