What the biggerst brakes anyone has stuffed under GSR Blades?
Old Nov 1, 2006 | 04:44 AM
CRXBart's Avatar
Default What the biggerst brakes anyone has stuffed under GSR Blades?
I have 11.1" plelude/Accord wagon brakes on my car, and was thinking of switching to GSR blades. Is anybody running this setup under blades? Or what setups are you running? It looks like there is a little room, but is it enough?
For those that nned pics:
Blades
My brakes, under my Koseis
Old Nov 1, 2006 | 10:13 AM
CRXBart's Avatar
Default Re: What the biggerst brakes anyone has stuffed under GSR Blades? (CRXBart)
Bump for I'm gonna pick these up this weekend if everything works out.
Old Nov 2, 2006 | 09:46 AM
FalkenSiR's Avatar
Looks like there will be little clearance. Refresh me on offsets again, aren't blades like ET45 or ET50? How about Kosei's?
Old Nov 2, 2006 | 09:47 AM
CRXBart's Avatar
Default Re: What the biggerst brakes anyone has stuffed under GSR Blades? (fast95eg8)
I'm not sure on my Kosei's offset. The Blades are 45.
Old Nov 4, 2006 | 10:21 AM
777sC's Avatar
i think you need 5mm spacers to make them fit ... but ill try to double check with a buddy that is running that setup at the moment
Old Nov 4, 2006 | 02:39 PM
CRXBart's Avatar
Default Re: What the biggerst brakes anyone has stuffed under GSR Blades? (777sC)
They fit no problems. Fit like a champ I'll post pics in the AM!
Old Nov 5, 2006 | 06:04 AM
CRXBart's Avatar
As promissed!
Old Nov 6, 2006 | 03:38 AM
JDM Like Whoa's Avatar
Good deal. I would be sure to pull the rim off after some driving and make 100% sure that there isnt any rubbing you cant see though.
Old Nov 6, 2006 | 04:29 AM
CRXBart's Avatar
Default Re: (ImportRacr05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportRacr05 &raquo;</TD></TR><TR><TD CLASS="quote">Good deal. I would be sure to pull the rim off after some driving and make 100% sure that there isnt any rubbing you cant see though.</TD></TR></TABLE>
There is 5mm of clearence at the closest point.
Old Nov 6, 2006 | 05:07 AM
How much bigger are these brakes than normal honda ones? What did you do to have to have them bolt on?
Old Nov 6, 2006 | 06:12 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportRacr05 &raquo;</TD></TR><TR><TD CLASS="quote">How much bigger are these brakes than normal honda ones? What did you do to have to have them bolt on?</TD></TR></TABLE>
They are normal honda brakes, from several different cars.
90 EX spindals
94 accord wagon claipers, bracket ground down 1mm
97 prelude vtec rotors redrilled to 4x100
it is a pretty standard setup.
Old Nov 6, 2006 | 10:48 AM
Noticeable stopping difference?
Old Nov 6, 2006 | 10:53 AM
CRXBart's Avatar
Night and day not to mention will last allot longer than 9.5" brakes or 10.3"s for that matter.
Old Nov 6, 2006 | 10:57 AM
You by chance have a writeup thread on this?
Old Nov 6, 2006 | 11:10 AM
CRXBart's Avatar
No but I'm sure there is one out there. This setup isn't uncommon by any means. Lots of people have done it. I've had mine on their for years. There was a website a long time ago that had a writeup about it, but I haven't been able to find it recently.
pkxfashion
Honda Fit
Nov 11, 2006 10:14 AM
CRXBart
19
Nov 5, 2006 06:03 AM
5poonhatch
Jul 18, 2006 05:47 AM
YellowGiser
Dec 17, 2003 09:35 AM
Mr. Softee
Dec 25, 2001 04:59 PM
