96 Spec R Integra Brakes Question
Gents,
For several of my clients, which have the 95-97 spec R I need info in regards to brake disks etc.
As you all know, spec R 95-97 comes with 4x114.3mm brake disks.
Since most of these guys want to upgrade their stock disk to slotted/Drilled, Slotted and Drilled Disks, I need to know, what model is exact the same from a other honda model (like accord) etc, to be fitted on Spec R integra with stock Calipers.
By this we can order from several performance stores in USA, brake disks to be fitted on Spec R 95-97.
I hope my question was clear, to receive good answers.
Rishi
Rishi
Prelude SRV brakes will fit...but rotors will be bigger, so u will also need the caliper bracket and i guess you should also get the caliper itself too.
Also you can use the GSR brakes, and get them redrilled to 4by114.3 pattern.
I personally went to the 5lug itr conversion, for the bigger brakes, and much easier time to get the spare parts for it.
Theres a huge write up about this on here...use the search feature, you'll be surprised at how fast it will find good info for u
thanks , I am open to search, but give me the keyword to search on!
Should i use> 96 spec R rotors??
let me know please
let me know please
https://honda-tech.com/zerothread/766629
scroll down a bit til you get to the info on "Brakes" and then there are like 4 different threads about only the 1996 itr brakes and different options of changing them.
Hope that helped a bit
20vsleeper
Suspension & Brakes
Oct 2, 2008 04:56 PM
