I have a 2000 Civic CX and want to run nitrous reliably. Is CAT on exaust manifold bad?
Old Oct 31, 2006 | 03:35 PM
Budget Racer's Avatar
Default I have a 2000 Civic CX and want to run nitrous reliably. Is CAT on exaust manifold bad?
Has any one put juice on a D16y7? It has the Catylitic converter on the exhuast manifold right by the motor. I was wondering if this is bad or restrictive for Nitrous use. PLus/Negitives Holla back someone Setup tips welcome!!
Also I could use a recomendation for someone in San Diego, California to tune my ride for a reasonable price.
Thanx, Budget Racer
Old Nov 6, 2006 | 09:06 PM
dafuzzbudd's Avatar
Default Re: I have a 2000 Civic CX and want to run nitrous reliably. Is CAT on exaust manifold bad? (Budget
the only thing about the cat that makes it restrictive is the fact that it's oem
placement doesn't matter.
you havent specified anything about the type of kit you want so you should look into that a little bit before you hurt your poor civic.
Old Nov 6, 2006 | 11:55 PM
Jimmy's Avatar
Global Moderator
It is not a good idea to run nitrous with a catalytic converter.. It's eventually just gonna stop up and be fucked.. Gut it if u can and get away with it (no emissions)
Old Nov 7, 2006 | 04:50 AM
dafuzzbudd's Avatar
Default Re: (Jimmy)
what about a high flow cat
Old Nov 7, 2006 | 10:52 AM
My system is very simple. Dry system, SAFC II, Walbro 255 fuel pump, B&M regulator & fuel pressure guage, & 1 heat range colder spark plugs.
Regarding CAT: I dont think they make a legal high flow cat for this model because it is a one piece unit off the exhaust manifold. I could just put an EX header there and go Catless though. I would rather do that so I could reuse CAT when necessary but its very loud.
The original reason I asked the question was because I burned one spark plug electrode when juicing (think I might have detonated a bit) but I didnt have the bigger fuel pump & regulator. I hope those items help the problem. Not sure if it was lack of fuel or poor flow cat. Thanx for all responses. :}
emgbc
Nov 16, 2012 05:41 PM
RacerXintegra2k
Nov 4, 2004 01:24 PM
Drag_On_RSX
82
Dec 26, 2001 05:33 AM
DaNish
Oct 26, 2001 01:20 AM
