Roebling Road Time Trials (SCCA)
This weekend is the annual TT at Roebling.
http://www.buccaneerregion.org
anyone attending? I can't wait to get out there on the fresh repaved track
who's putting it on?
theres also an auto-x the 19th at Hutchinson island,Ga. for any one else interested..
we are all set, will be on track at 9 in the morning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote">we are all set, will be on track at 9 in the morning
I hope so, good luck and remember not to test the new cage... at your first event with it like I did
</TD></TR></TABLE>I hope so, good luck and remember not to test the new cage... at your first event with it like I did
So, today went well. ran 3 sets of wheels, started off with the 14's with the old azenis, practice no times, just alot of tire screech, couldnt get into the throttle untill exit of corner.
then i went with the 15's with toyos, 225 in the front 205 rear. took longer to rev noticable difference, alittle more stick. ran a 1:26.7
later in the day i put on the 13x8's with kumho 710's, ran 1:25.8 but hitting the speed limiter in 4th at the start finish line. tried 5th but cuts at the same speed, 123mph..
i had to keep the revs at 6200 to keep from bouncing and slowing down
i need final drive.
Melissa ran 1:34.xx so she has alittle room for improvment but doing very well
i will put the toyos back on in the morning and try to push harder. my video sucks too much wind noise, i need a roll bar mount for my camera.
i need final drive.Melissa ran 1:34.xx so she has alittle room for improvment but doing very well
Sounds good so far, how did you like the new surface?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote"> i had to keep the revs at 6200 to keep from bouncing and slowing down
i need final drive.
You need a new ecu, but the final drive sure wouldnt hurt.
i need final drive.</TD></TR></TABLE>
didnt you tell me at some point where to send my ECU? I ended up running a 1:25.9 on the 15's w/toyos. Ill post video later, i moved the camera to a better spot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote">who's putting it on?
http://www.chinmotorsports.com
</TD></TR></TABLE>http://www.chinmotorsports.com
B18C5 EH
Mar 19, 2005 07:41 PM
Jack Black
Sep 13, 2004 07:22 AM
trumperZ06
Jun 14, 2003 07:24 AM
