axel question with bfg DR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">preload it and dont dump your clutch...</TD></TR></TABLE>
listen to this guy^^^ he is the drag radial king
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">
listen to this guy^^^ he is the drag radial king</TD></TR></TABLE>
LOL
ive had 3 sets of slicks ive never used.. n 3 sets of bfg's that ive used till the core.....
LOL
I have never preloaded, and only broke one due to wheel hop from an extensive burnout.
I would go for the damn neer rev limiter launch on a damn near stock b16
Modified by fmfkid250 at 12:20 AM 11/3/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropcivic »</TD></TR><TR><TD CLASS="quote">How do y'all preload? I have heard different ways and wondering what works best for y'all. We broke 2 gator axle on bf radials. No wheel hop, 4000 rpm launch. </TD></TR></TABLE>
what your supposed to do is...
do burnout
pull up to the line
prestage
pull up ebrake handle slighty
slip clutch slighty to pull into the second beam
get on the 2step while still slighty slipping clutch
goes green
let the clutch out the rest of the way while getting off ebrake
you want the clutch to do the work
do burnout
pull up to the line
prestage
goes green
I never heard anything real good about gators,
did u ever try OEM axles? they seem to be alot better then REmans
from what i understand about preloading get staged then pull the ebrake up build some boost (let the clutch out so it squats) then light goes and let off and go!@
I do not have a twin disk so this would trash a clutch in a few passes If not make it slip
Oct 4, 2003 10:13 AM
