92-95 civic question
hello, i am having trouble finding my clutch bleed screw. is it around the clutch fluid reservoir?
also, is there a hole thru the firewall(i think thats whats its called) to my dash? i want to hook up some wires from battery to dash. thanks for help.
There is a rubber plug to the right and down from your battery. If you put a hole in that plug you can feed a wire thru there. It's easier to push the wire from the engine compartment side. It will bump up against the air box on the inside and you have to fish it toward the floor board.
Remove that plug before putting a hole thru it. You don't want to drill into your airbox.
Yea, I have the manual with the pictures and everything, but I just don't know where in the car it is. Like middle, front, rear of engine bay, left or right, etc.
I'll check the left of the headers area. Thanks
Ok, so is this the nipple you are referring to?
http://picasaweb.google.com/ja...02066
Excuse my rust spots and stuff, it was already there when I got it!
Modified by black94boost at 3:52 PM 11/1/2006
Modified by black94boost at 3:53 PM 11/1/2006
minimarine09
May 18, 2014 05:47 PM
Luke G.
Apr 25, 2009 03:13 PM
JKingCivicSi
Jun 15, 2007 03:59 PM
