B16 Swap question (its a quick one)
Ok guys and gals Im sure you are sick and tierd of these threads and I apologize for another one. Here is my question! I picked up a wrecked 00 SI and Im going to be pulling the motor and putting it in my car which is a 97 EK hatch. My question is can I just use the wiring harness on the motor B16? I believe I've read some where that you can't because of the difference is OBD2a and OBD2b but I figured I would ask anyways. Thanks in advance for any help...If I can't I just plan on buying a EX Harness and going about it that away...
Thanks in advance guys and gals...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB »</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96dx »</TD></TR><TR><TD CLASS="quote">You can't use the 00 si harness because it's obd2b your dash harness won't plug into it. You need a obd2a ecu and harness. 96-98 is obd2a and 99 and up is obd2b</TD></TR></TABLE>
sorry you are correct
Thanks alot.... Well I guess since Im going to swap the dash and climate control along with internal harness I'll be good to go.. Thanks alot man...
:::SIRll_EJ1:::
Sep 26, 2008 10:33 AM
B16aCRXSi
18
Apr 3, 2006 10:53 AM
forlorn76
May 10, 2003 01:35 AM
